Old 01-10-2011, 08:44 PM   #1
Snowman
Snowman's Avatar
Snowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this place
87 Iroc Supercharged BHP 357 SINGLE PLANE w/ megasquirt & complete repaint
Well, as many know I bought the 1987 blur LSR style Iroc on here back in July. It wasn't an expected buy, but at the time I felt I was getting such a good deal that I sold off parts from my yellow 86 build and concentrated on this car. Some of the pictures are really bad as they are BB pictures in the dark, BUT I wanted to take you along with me on a ride through the car so far. It's come a long way in a short amount of time and I'm doing everything I can to keep up the pace even though we are buying a house next month. Plans are for it to be on the road by the end of next month.
Although this thread is mainly about the engine/computer, paint, etc it has TONS of great parts on it. The brakes and suspension are awesome. The cage and chute really ad to the look and function. It also has a full fire suppression system in case things get ugly... Well, enough of that here is it's history...
July 17th.... The ad was posted. Here is the description and picture from it. Love at first sight!
WHEEL AND TIRES-
19x8 Auto Art 3 piece VY design front
19x10 Auto Art 3 piece VY design rear
275/35ZR19 Bridgestone Pontenza RE050
295/35ZR19 Bridgestone Pontenza RE050
SUSPENSION-
BMR Tubular K-Member
BMR Tubular Lower Control Arms
Eibach Sportline spring kit
KYB Adjustable front Struts and rear shocks
Energy Suspension urethane bushing kit – full car
Hotchkis front strut brace
Hotchkis front and rear sway bars
Hotchkis tie rod connectors
Hotchkis sub frame connectors
Hotchkis adjustable pan rod bar
Hotchkis trailing arms
Spohn Performance caster/camber plates
Edlebrock adjustable torque arm
Competition Engineering 12-point roll cage
Manual S-10 gearbox swap
BRAKES-
Baer Track Plus front and rear
Holley line lock
DRIVETRAIN-
Center Force DX Clutch System
Center Force SFI flywheel
Borg-Warner T-5 World Class Transmission (AXED)
B&M short throw shifter
Inland Empire Driveline aluminum driveshaft
CT Tuners custom 10 bolt-
Moser Street/Strip axles
Richmond 2.73 gears
Richmond Power Trax locker system
Moroso pro wheel stud kit
Custom Summit aluminum diff cover w/ fabricated supports
SPC fabricated tube supports
INTERIOR MODS-
Sparco Torino seats
Sparco Steering wheel
Sparco aluminum pedals
Sparco shift knob
G-Force 5-point cam lock harnesses
G-Force Window net kit
G-Force arm restraints
Ignited carbon fiber switch panel
White gauge kit
Autometer double pillar gauge pod
Autometer Phantom air/fuel ratio meter
Autometer Phantom 30psi boost gauge
Autometer Phantom NOS/Cryo gauge
Autometer shift light
MSD digital 6 ignition control
MSD knock sensor meter
APC blue fire bottle
SOUND (ICE)-
Sony flush mount CD changer
JBL Audio 3x5 w/ titanium tweeter
JBL Audio 6x9 w/ titanium tweeter
EXTERIOR MODS-
Custom paint by Rich Antoneck
Carbon Creations universal side splitters
Carbon Creations fabricated rear under car diffuser
Clear parking lights
Clear turn signals
Fiberglass IROC cowl induction hood
Custom Vinyl by Right On Signs
ENGINE MANAGEMENT-
O.E. General Motors
My own creation of a FIC with 150 lbs Accel fuel injectors (2 bar map)
ENGINE-
Vortech V7-Ysi supercharger
Vortech Polished intake elbow
Vortech Super FMU
Vortech altered blower bracket
ASP fabricated custom carbon fiber poly cogg system
TIAL 50.5mm blow off valve
Spearco 6 core sheet metal after cooler
AEM custom blower intake
Lingenfelter matched fuel injectors
Altered GM fuel rails with fabricated adapters
MARCH polished aluminum pulley and bracket set
TCI Rattler harmonic balancer
Moroso blower return oil pan
Moroso polished aluminum valve covers
MSD billet distributor
MSD Blaster coil
MSD Boost Timing Master
Crane Cam roller camshaft
Comp Cam non-pump up roller lifters
Taylor 10.4mm Pro ignition wires w/ keepers
K&N chrome breather
Optima Spiralcell Red top battery
Be Cool catch can
Hooker Header ceramic big-tube headers w/ O2 sensor mod
Mandrel 3-inch dual exhaust w/ “H” pipe
Flow Master 40 series dual mufflers
Holley 58mm dual port throttle body
Aeromotive fuel pump A1001
Aeromotive fuel pump controller
SLP altered and ported polished runners
Custom altered and ported top and base plenum
Carbon Creations engine compartment accents
Moroso solid engine mounts
Moroso oil cooler
Moroso high flow water pump
Polished alternator
Accel Phantom fuel pressure gauge w/ chrome cup
PRIMARY NUMBERS-
848 ft-lbs torque 3.33 pulley / 945 ft lbs torque 2.85 pulley on 305cid Tuned Port
Injection w/ race internals.
PRIMARY ENGINE-
SRP flat top forged piston set
Swain Technology Inc. Gold Coat ceramic armor and PC-9 solid lube sides
Eagle forged H-Beam rods with ARP bolts
Eagle forged and balanced crank shaft
ARP head and main stud kits
Moroso high flow oil pump
Edlebrock Performer centerbolt aluminum cylinder head (worked for blower)
SCE ICS Titan head gaskets
Comp Cams timing belt drive system
Lunati forged roller rockers w/ Lunati push rods
Dusty and I ended up there that night to look the car over. The car was in a small garage, but we looked it over pretty well and were blown away by the attention to detail on some of the things on this car! We struck a deal and the next day Adam P and I trailered down the BHP trailer and loaded it up. Here are a couple crappy BB shots of that night....
Loaded up in the trailer to it's new home...
It had a little coolant smell, but no big deal we figured... He stated he thought it had a slight issue on the passenger side head gasket. Darren threw together an impromptu photo shoot the next day and a local school.
Quick video from the day after I got it...
1985 Iroc
1986 Iroc
2009 G8 GT
Snowman is offline   Reply With Quote
Old 01-10-2011, 08:53 PM   #2
kyphur
off 2 sea a wizrd, brb
kyphur's Avatar
kyphur is without a doubt too mature for this placekyphur is without a doubt too mature for this placekyphur is without a doubt too mature for this placekyphur is without a doubt too mature for this placekyphur is without a doubt too mature for this placekyphur is without a doubt too mature for this placekyphur is without a doubt too mature for this placekyphur is without a doubt too mature for this placekyphur is without a doubt too mature for this placekyphur is without a doubt too mature for this placekyphur is without a doubt too mature for this place
I've always liked that car man.
Jason
My Fquick
kyphur is offline   Reply With Quote
Old 01-10-2011, 08:56 PM   #3
ghall
ghall might have posted something useful at one time
I wish i would've bought that car when i first saw it for sale. There was a mint put in it before you got it.
87 Buick GNX-9K miles, stock
05 Dodge Daytona Ram 4x4 ---my DD
08 Corvette Z06
ghall is offline   Reply With Quote
Old 01-10-2011, 08:57 PM   #4
1LoudTransam
"Cam Only"
1LoudTransam's Avatar
1LoudTransam might have posted something useful at one time
Great car man. Still glad you got it!
1LoudTransam is offline   Reply With Quote
Old 01-10-2011, 09:24 PM   #5
Snowman
Snowman's Avatar
Well, on 9/20/10 the yellow Iroc left for it's new home on the OTHER side of the Colorado rocky's. It was bittersweet to say the least, but I knew it was time
First thing I started on was pulling all of the stickers off of the car. It was a little too stickercharged for my taste. I got almost all of them off and on the ver last one on the passenger side the "Grand Sport" stripe pulled off some paint on the passenger side. I was upset, but before the end of the week had something worked out with Robbie at Absolute Body to get it touched up along with a few spots here and there soon. With that being said I loaded it up on the trailer and brought it over to bananaman's house(Also my uncle) to tear into the motor and replace some blown head gaskets.
It matches my trailer well
After I got it there I first used an old 4th gen seat to make the Sparco's slide(were mounted solid) and then uninstalled the narrow band O2 sensor and got the wideband AEm wired in and loosely mounted. Moving up to the engine I had one thing on my mind and that was getting those heads off. it was meant to be a simple head gasket(or maybe throw on my AFRs if everything worked) and be done for now. Plans were to upgrade the computer system after the Spring...
Before I got started...
The power adder!!! Vortec YSi with a polycog setup. Have pulley's for up to 25 lbs of boost and with the cogged setup slipping should not be an issue...
Other side... Tial Blowwoff(surge protector), oil catch can, and you can also see the beautiful Moroso valvecovers. Closer to the throttle body you will see the aquamist extra injector setup that after seeing the damage below i decided to ditch along with teh stock computer(INCLUDING STOCK CHIP!) for a MS II setup that is using some of the stock wiring, but a complete Megasquirt ECM and 4 bar map...
Well, got the heads off and was immediately dissapointed for a few reasons
-4.15 head gaskets on a 3.95 bore 305
-both head gaskets blow very badly
-slight cylinder wall damage due to coolant sitting in it for extended periods
-#1 piston had damage to it from a severe lean/detonation condition
Here are some pictures stripping down the block, and pulling the ECM wiring to bring it to a friend in Charlotte to convert it over to megasquirt for me...
1985 Iroc
1986 Iroc
2009 G8 GT
Old 01-10-2011, 09:32 PM   #6
Snowman
Snowman's Avatar
Well, after seeing all the things that needed attention in the motor we decided to go ahead and yank it and install a fresh 355 we had waiting to go in the turbo car. A quick cam change and buttoning it up and it would be ready. Pictures on specs on the motor to follow. Now back to the removal of the old 305!
Here bananaman(my uncle), his son, and Mark(roadkill) get the motor out of the car while I stand around and take pictures
ITS FREE!!!
After it was all the way out we could really take an invetory of the parts on the motor and also check all of the damage
Closeup of the piston with a bad mark on it. Also not the etching in the cylinder wall, most likely from coolant sitting in there for extended periods.
Drained the oil(What was left of it)
Really like the external timing belt, but I already have a nice two-piece billet one on the 355. Also note the rattler balancer!
The 305 had some VERY nice splayed for bolt mains on it...
Nice H-pipe setup on the car with "fake cats'", flowmasters and the only bolts you have to remove to get it off are the collecter bolts. The rest is hung from the car with high quality rubber exhaust mounts. Very tight system!
Not shown are the dual aftermarket fans, huge Be Cool radiator, and Spearco intercooler that can only be removed if the front bumper is also removed!
1985 Iroc
1986 Iroc
2009 G8 GT
Old 01-10-2011, 09:37 PM   #7
dcs1991
They see me trollin'
dcs1991's Avatar
dcs1991 might have posted something useful at one time
sucks to hear the engine was in that bad of shape. still a bad ass car for sure!
04 GT: looks fast, sounds fast, but moves slow as hell
dcs1991 is offline   Reply With Quote
Old 01-10-2011, 10:07 PM   #8
Snowman
Snowman's Avatar
After the engine was out we figured a few other things should be taken care of as well...
New plans included
-355 with AFR heads
-Stock ECM gone and replaced with a MS II system with 4 bar map
-aquamist FIC system thrown in the trash(well for sale)
-Vortech super FMU and 36 lb injectors gone and replaced with 8 80 lb ones run by the MS setup
-Boost retard box removed
-Aeromotive Fuel pressure regulator added with CF gauge
-Update the fuel lines and fix a few parts on the custom fuel rails to allow for much more flow
(Updates and pictures on those other things soon!)
Motor specs are a simply SBC build that should handle boost(25 lbs at sometimes!)
-355
-splayed 4 bolt mains
-6" Carillo rods
-AFR 195 cc heads
-CP pistons
-8.5/1 compression
-Custom comp cam
-all TPI parts are gasket matched, but retaining the stock looking TPI(SLP runners, 58mm TB, siamesed runners)
Dusty adjusting the rocker arms while I again stand and take pictures...
Cleaned, painted, and polished WP waiting to go on...
I also removed the harness as stated above so that I could get it to Sam in Charlotte so he could convert it all for me... After that was out along with the motor I got the wheels swapped just because they are worth about $8k before bringing it over to Robbie at Absolute body
19's
chrome ZR1's on and ready to go in for paint!
1985 Iroc
1986 Iroc
2009 G8 GT
Old 01-10-2011, 10:19 PM   #9
Snowman
Snowman's Avatar
Next we loaded up the car and bbrought it over to Robbie. He was going to touch up a few spots and just get it presentable for me!
Well, after looking at it a couple minutes we noticed there were some primer still showing in some spots and some parts where the paint was so thin you could see primer under it. Luckily the car was in the right place to get it all repaired and taken care of. We decided to do a full strip down of the car and repaint! We are also getting rid of the four slider hood pins and replacing them with 2 aerocatch hood latches like below. We are going to paint them black to add some contrast to teh hood!
After they started to tear into the car we found out it has 3 coats of paint(including the factory paint job), 5 on the nose, rust under the T-top, ill-fitting hood, bad driver's side door hinges, and bondo on a few places.
It's current state
Check out the fire suppression runing over the passenger side tower! It has two nozzles under the hood!
There was a real rat's nest under the rear bumper!
5 coats on the bumper and some cracks
The spoiler has never been off! It had a large ridge on it whenb it was removed. 3 coats on it!
1985 Iroc
1986 Iroc
2009 G8 GT
Old 01-10-2011, 10:26 PM   #10
Heater
Tastefully Sarcastic
Heater's Avatar
Heater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this place
That is a awesome car you have there Chris
Originally Posted by NufNuffz28 View Post
Damn! Ford Motors are so awesome!
Heater is offline   Reply With Quote
Old 01-10-2011, 10:34 PM   #11
Lunchbox
Stab
Lunchbox's Avatar
Lunchbox is without a doubt too mature for this placeLunchbox is without a doubt too mature for this placeLunchbox is without a doubt too mature for this placeLunchbox is without a doubt too mature for this placeLunchbox is without a doubt too mature for this placeLunchbox is without a doubt too mature for this placeLunchbox is without a doubt too mature for this placeLunchbox is without a doubt too mature for this placeLunchbox is without a doubt too mature for this placeLunchbox is without a doubt too mature for this placeLunchbox is without a doubt too mature for this place
Sticker removal mod coming or will the sponsors follow the transfer of title
Lunchbox is offline   Reply With Quote
Old 01-10-2011, 10:34 PM   #12
Snowman
Snowman's Avatar
Done for tonight!
I'll update as we progress!
1985 Iroc
1986 Iroc
2009 G8 GT
Old 01-10-2011, 10:36 PM   #13
Snowman
Snowman's Avatar
Check the pictures towards the bottom of the thread. All coming off!
1985 Iroc
1986 Iroc
2009 G8 GT
Old 01-10-2011, 10:39 PM   #14
Lunchbox
Stab
Lunchbox's Avatar
ah, i missed those. good work.
keep it up. this will make a nice trade in towards a 2012 5.0 when your done.
Old 01-11-2011, 02:24 AM   #15
dklimek
Lurking in the shadows..
dklimek is a good little Junkie
WOW! I saw that car a while ago at one of our meets in wilmington, never thought it would be getting EVEN BETTER!! You are sticking with that color blue I hope?!
Originally Posted by Clint Eastwood View Post
You ever notice how you come across somebody once in a while that you shouldnt have messed with?...well thats me.
www.turbofordcentral.com
dklimek is offline   Reply With Quote
Old 01-11-2011, 05:43 AM   #16
looks awesome man, I loved that car when I saw it as well
Old 01-11-2011, 06:49 AM   #17
Looking good!! Are we looking at a 1000hp 355 or should the power be around the same?
Old 01-11-2011, 07:00 AM   #18
Snowman
Snowman's Avatar
Yeah, it had a few defeciencies that we are taking care of and thanks for the compliments!
-The color will be the exact same "Iroc Blue"
- Honestly i'm not sure about the power. There should be an increase with better components, more cubes, AFR's, gasket matched intake, larger cam, but I know the SC can only shove so much air through the TPI. I know if I ever get off of my "TPI high-horse" it would make 1000hp!
1985 Iroc
1986 Iroc
2009 G8 GT
Old 01-11-2011, 07:11 AM   #19
Tank
The NO-GO Monte Carlo
Tank's Avatar
Tank is a good little Junkie
Good Luck with the build Chris!
1988 Monte Carlo SS
2006 Silverado Crew Cab LT
2009 Malibu 2LT
Tank is offline   Reply With Quote
Old 01-11-2011, 07:13 AM   #20
HITMAN
Cause racecar
HITMAN's Avatar
HITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this place
I know I have asked before but dont remember your answer, but what is your plan for the car? Drag, road race, mile?
HITMAN is offline   Reply With Quote
Old 01-11-2011, 07:24 AM   #21
Snowman
Snowman's Avatar
Thanks
Ya know Thadd a little of everything. It won't be much of a drag car with the way it is set up now. It will be more of a street car than anything. I do want to go to the standing mile and Roadcourses some though!
1985 Iroc
1986 Iroc
2009 G8 GT
Old 01-11-2011, 07:24 AM   #22
blazinbowtie99
blazinbowtie99's Avatar
blazinbowtie99 is without a doubt too mature for this placeblazinbowtie99 is without a doubt too mature for this placeblazinbowtie99 is without a doubt too mature for this placeblazinbowtie99 is without a doubt too mature for this placeblazinbowtie99 is without a doubt too mature for this placeblazinbowtie99 is without a doubt too mature for this placeblazinbowtie99 is without a doubt too mature for this placeblazinbowtie99 is without a doubt too mature for this placeblazinbowtie99 is without a doubt too mature for this placeblazinbowtie99 is without a doubt too mature for this place
I <3 this car! Looking good, Chris.
blazinbowtie99 is offline   Reply With Quote
Old 01-11-2011, 07:36 AM   #23
91GT347
Dr. Greenthumb
91GT347's Avatar
91GT347 might have posted something useful at one time
Have you thought about swapping the stock style TPI for a Accel super ram, or TPIS mini ram ? Im sure that would help you some too. I ran the Super Ram on my 406 in a 85 Iroc. The Mini Ram may be a little better though. I used alot of Lingenfelter stuff. They were always great to deal with for me. A little pricey though. Also how did you fit true dual 3" pipes under there ? Without it being 3" off the ground anyway. lol
SOB !!! I'M ALMOST OUT OF GAS !!
91GT347 is offline   Reply With Quote
Old 01-11-2011, 07:36 AM   #24
1fast10
rs275 here i come
1fast10's Avatar
1fast10 is actually making some sense.1fast10 is actually making some sense.1fast10 is actually making some sense.
huge fan of this car. good luck on the rebuild
84 s-10 with a small motor
5.8@120.slow as hell
1fast10 is offline   Reply With Quote
Old 01-11-2011, 07:40 AM   #25
Snowman
Snowman's Avatar
Originally Posted by 91GT347 View Post
Have you thought about swapping the stock style TPI for a Accel super ram, or TPIS mini ram ? I ran the Super Ram on my 406 in a 85 Iroc. The Mini Ram may be a little better though. I used alot of Lingenfelter stuff. They were always great to deal with for me. A little pricey though. Also how did you fit true dual 3" pipes under there ? Without it being 3" off the ground anyway. lol
Yeah, I have. I just really like the fact it still has TPI! Maybe down the road when money allows I'll upgrade to something(probably a miniram) and make a lot more power. For now, torque all day and a Ysi will be fun on the street.
Its close to the ground, but the main thing is tucking it as close to the body as possible. We didn't do this one, but have done a few on thirdgen's before. Dusty's 85 Iroc has a very similar setup we did on his car.
1985 Iroc
1986 Iroc
2009 G8 GT
fuckmegasquirt, GAYEST VIDEO EVER!!, haters in this tag, Heater approved, Ice Cream Paint Job!, IROCMALL, ItMightLookGood, no black?, overuse of fisheye, shitsweak, weakestYSIever
