Go Back   HorsepowerJunkies.com Forums > Classifieds > Parts and Accessories For Sale
Old 11-01-2022, 06:45 PM   #1
nastymustang
nastymustang's Avatar
nastymustang has no rep around here.
Lots of mustang parts for sale
408 stroker motor in a 69 model block complete fogger to oilpan and proven to go the numbers with Afr 225 heads(will need a piston replaced) 7,000.00 as is firm serious inquires only
347 stroker long block includes Edelbrock victor jr heads,cast steel crank ,I-beam rods,mahle forged pistons,cam motion custom camshaft,electric water pump,main support,studs and aftermarket oil pan all for 4,500.00 Firm
331 stroker shortblock includes a cast steel crank,h-beam rods,mahle forged pistons,comp custom nitrous camshaft,water pump,canton oilpan all for 2,500.00 firm(needs bearings)
331 stroker long block includes Edelbrock victor jr intake and heads,cast steel crank ,I-beam rods,mahle forged pistons,comp custom nitrous camshaft, water pump, oil pan all for 4,500.00 Firm
331 stroker long block includes Edelbrock performer heads,cast steel crank ,I-beam rods,mahle forged pistons, comp cams flat tappet camshaft, water pump, oil pan all for 4,500.00 Firm
(1) 5.0 ho longblock with 93,000 actual miles in great condition for 1,200.00
(1) 5.0 ho longblock for 1,200.00 each
(1) 5.0 ho longblock low miles on freshened ready to go for 1,200.00
(1) 302 standard bore mid 70s block for 150.00
(1) 302 standard bore 5.0 xxx roller blocks for 300.00 each
(1) 302 standard bore shortblock that needs rebuilding for 400.00
Jomar stud girdles for tfs and canfield heads like new for 100.00
3 sets of Hpm solid motor mounts used for 80.00 each set
energy suspension motor mounts like new for 125.00 a set
automatic pedals for foxbody used for 100.00
Aod stock converter like new for 100.00
10" 3500 convertor with anti balloon plate for c4 used for 650.00
10" 3500 convertor for a turbo 350 transmission used for 250.00 firm
(3) Ford racing aluminum driveshafts for mustang used 300.00 firm each
(1) Ford racing aluminum driveshaft with a 31 spline yoke for mustang used 300.00 firm
Mustang Driveshaft Spacer with bolts 11/16" Thick new for 40.00
Upr driveshaft loop new for 40.00
(2) Upr driveshaft loops used for 30.00 each
T-5 bell-housings for a foxbody used for 250.00 each
Complete T-5 5 spd world class transmission setup includes a 4cyl transmission with v-8 bellhousing,plate,clutch fork,B&m shifter and clutch, pressure plate and release bearing all for 900.00
(1) T-5 5 spd world class transmissions with low miles on rebuild for 1,200.00
T-5 transmission for a 94/95 mustang gt with bellhousing and clutch fork for 1,200.00
Aod transmission in great condition with very low miles on rebuild and shift kit for 1,200.00
C-4 transmission with forward pattern valvebody,Red clutches, small bellhousing, Kevlar bands, billet servo and deep aluminum pan low miles on build for 1,200.00
C-4 transmission with a forward pattern valvebody,Red clutches, small bellhousing, Kevlar bands for 1,200.00
fan shroud with overflow for foxbody used for 75.00
Fluidyne aluminum radiator for 94-98 mustang like new for 300.00
Mishimoto alumium radiator for mustang used for 200.00
Howe racing alumium radiator for mustang with quick connects and cap brand new for 250.00
(1) aluminum 3 core radiator used for 180.00
Afco aluminum radiator with electric fan both used for 200.00
(1) 3 core radiators used for 100.00 each
hurst roll control part#174-5000 like new for 80.00
B&M ratchet shifter for forward pattern c-4 transmission with cable for 275.00
B&M prostick shifter for a powerglide transmission like new for 325.00
B&M prostick shifter for a c4 transmission forward pattern like new for 325.00
Steeda tri ax shifter for tko like new for 140.00
Mgw shifter for tko 500/600 used for 140.00
Mgw shifter for T-5/T-45 used for 140.00
upr shifter almost new for 125.00
(2)B & M ripper shifters for mustangs in good condition for 125.00 each
hurst short throw shifter used for 100.00
(3) pro 5.0 shifters with handles for 130.00 each
ford racing A351 1.6 pedastal mount rockers part#m-6564 like new for 250.00
Prw 1.6 7/16 stud roller rockers brand new in the box for 200.00
Comp cams high energy 1.6 7/16 stud roller rockers like new for 150.00
BBk part #1559 pulleys like new for 100.00
(3) race crank pulleys used for 35.00 each
Painless wiring 4 switch panel for ashtray new for 135.00
(1) sets of Arp head bolts used for 351 100.00 a set
1 set of arp studs brand new in the box part #154-4005 for 130.00
1 set of 7/16 arp head studs like new for 100.00
rpc sheet metal valve covers for sbf new in the box for 200.00
rpc crank case evacuation system part# R2050 new for 30.00
sheet metal valve covers for sbf motor used for 80.00
Mustang in tank pickup tube with an fittings new for 85.00
Holley black fuel pump in good condition for 125.00
(2) 255 lph fuel pumps brand new for 90.00 each
255 lph fuel pump like new for 80.00
Magna fuel quick star 300 pump like new for 375.00
Holley 12-803 - Holley Fuel Pressure Regulators new for 35.00 each
(7) sets of Ford motorsport 24# injectors used for 125.00 each set
85 mm.slp mass air meter for 98 thru 02 ls1 cars for 125.00
summit brand part#g4961 transmission cooler new in plastic for 30.00
Holley 670 street avenger carburetor like new for 300.00
Holley 850 carburetor in good condition for 300.00
(2) edelbrock victor jr intakes for carb 302 in great condition for 350.00 each
1" phenolic spacer for trickflow street heat used with no bolts for 40.00
1" phenolic spacer for edelbrock rpm 2 intake used with no bolts for 40.00
(1)1" phenolic spacers for edelbrock rpm intakes used with bolts for 50.00 each
1" phenolic spacer for gt40 intake used with no bolts for 40.00
(2) 1/2" phenolic spacer for stock intake used with no bolts for 30.00
Gt40 ported lower intake with a custom sheet metal upper intake and nitrous plate to match all for 950.00
Edelbrock performer efi upper and lower intake in good condition for 950.00
(2) Edelbrock performer rpm efi upper and lower intakes in good condition for 1,000.00 firm each
Edelbrock performer rpm 2 part# 71233 efi upper and lower intake brand new in the box for 1,500.00 firm
(1) gt-40 explorer uppers for 150.00 each
BBk cold air kit for 94/95 mustang like new for 150.00
Cold air kit for 87 thru 93 mustang new for 100.00
(2) BBK Cold air kits for 87 thru 93 mustang used for 100.00 each
Professional products 65mm.throttle body and spacer for 87 thru 93 in good condition for 160.00
professional products 70 mm. throttle body like new for 150.00
70mm. egr delete used for 45.00
Bbk 65mm. throttle body used for 140.00
Edelbrock 70mm throttle body used for a foxbody for 150.00
(2) Bbk 70mm. throttle body and spacers for 87 thru 93 in good condition for 175.00 each set
trickflow 6.500" .080 pushrods in good condition for 90.00
trickflow 6.550" .080 pushrods in good condition for 90.00
(2) sets trickflow 6.700" .080 pushrods in good condition for 90.00 a set
5/16 x 7.000 .083 pushrods in good condition for 90.00
trickflow 7.00" .080 pushrods in good condition for 90.00
7937 competition cams 7.050 .080 pushrods in good condition for 120.00
trickflow 7.800" .080 pushrods in good condition for 90.00
comp cams 7.900" pushrods used for 90.00
302 timing cover brand new for 100.00
(2) edelbrock victor jr solid roller springs like new for 75.00 a set
Lunati 602/602 solid roller camshaft with a 108 lobe separation part#51019lun used for 250.00
comp cams 692/673 solid roller camshaft with a 108 lobe separation like new for 250.00
comp cams 576/585 Hyd roller camshaft with a 110 lobe separation like new for 250.00
comp cams 555/570 NX274HR-14 Hyd roller camshaft and lifters both like new for 250.00
reed brand 503 lift hyd flat tappet camshaft in good condition for 100.00
(2)Taylor aluminum battery boxes new for 90.00 each
1 factory ford mini starter used for 75.00 each
professional products neutral balance balancer for ford motor in good condition for 125.00
high performance 50 oz balancer like new for 150.00
professional products 80007 balancer new in the box for 85.00
(1) 28 oz. 157 tooth flywheel for ford used for 175.00 each
(6) 50 oz. 157 tooth flywheels stock 87-95 for 50.00 each(need surfacing)
(1) 28 oz.flexplate 157 tooth for ford used for 85.00 each
(1) 28 oz.flexplate 164 tooth for ford used for 85.00 each
(1) 28 oz.flexplate 164 tooth accepts ford of gm converter like new for 125.00
(4) 50 oz.flexplates 157 tooth for ford used for 85.00
(2) 50 oz.flexplate 157 tooth for accepts ford of gm converter like new for 125.00
50 oz.flexplate 164 tooth for ford used for 85.00
(2) Bbk power plus fuel pressure regulator like new for 94/95 mustang for 90.00 each
paxton fuel pressure regulator like new for 94/95 mustang for 90.00
(3) kirban fuel pressure regulators for 86 thru 93 mustang used for 90.00 each
(1) 99 thru 04 gt rear bumper cover new takeoff for 200.00 firm
94 thru 98 billet grille with running horse in it used for 65.00
99 thru 04 aftermarket tailights in good condition for 100.00
(2) sets of 87-93 lx taillights for 175.00 each set
01 thru 04 factory gt spoiler in good condition for 100.00
99 thru 2000 factory gt spoiler in good condition for 100.00
87 thru 93 factory gt rear spoiler in good condition for 100.00
factory white rear spoiler for 94 thru 98 mustangs for 75.00
(1) 87 thru 93 stock mustang hoods 200.00 each
99 thru 04 power seat track in good condition for 80.00
black poly race seat brand new for 35.00
Rci harness part #9210d new in the box for 60.00
2001 cobra seat for 100.00
moroso spark plug wires brand new for 50.00
ford racing wire sets in good condition for 30.00 a set
(1) msd 8456 distributers for 86 thru 93 efi in good condition with bronze gear for 225.00 each
(1) msd 8456 distributers for 86 thru 93 efi in good condition with steel gear for 225.00 each
(1) msd 8582 distributer with steel gear for 5.0 mustang new for 320.00
(1) msd 8582 distributers with steel gear for 5.0 mustang in good condition for 200.00 each
(2) msd 8582 distributers with bronze gear for 5.0 mustang in good condition for 200.00 each
(1) Msd billet distributer part#8451 for a 351windsor for Sn95 for 300.00 Like new
(2) holley laser shot coils in good condition for 40.00 each
(2) msd blaster cannister style coils for 40.00 each
(1) msd high vibration cannister style coil for 40.00
(5) msd blaster tfi coils used for 40.00 each
(1) msd blaster ss part#8207 new for 40.00
(1) accel super coil part#14008 used for 40.00
Holley quick shot ignition system with hand held programmer and all for 300.00 obo.
1 msd 6t in good condition for 125.00
(2) msd digital 6al boxes new in the box for 300.00 each
(2) msd 3 stage retard boxes part#8970 like new for 150.00 each
(3) msd multi stage retards part#8975 for 175.00 each
msd start retard box part#8982 used for 100.00
(4) 18" 5 lug silver 5 star wheels and perelli 235/50/18" tires off of an 2012 gt mustang gt with 1000 miles all for 850.00
(4) 17"premium package 5 lug silver wheels and perelli 235/55/17" tires off of an 2006 gt mustang gt with like new tires all for 650.00
(4) 17 x 9" 5 lug 03/04 cobras with 275/40/17 nitto 555 tires on the front with less than 2,000 miles on them and new with the stickers 285/40/17 on the rear for 1,000.00 firm
03/04 chrome cobra staggared setup includes 17x8" fronts with 245/45/17 tires and 17x9" rears with new 275/40/17 street tires all for 1000.00 firm
(3) 17 x 8" 5 lug 05 gto wheels for 200.00
(2) 17 x 8" silver bullet wheels with bad tires for 94 thru 04 mustang in good condition for 150.00
(2) 17 x 9" silver silver cobra wheels with 1 like new tire and 1 worn for 94 thru 04 mustang in good condition for 150.00
(4) 17 x 8" polished upgrade cobra wheels for 99 thru 04 mustangs in great condition with 245/45/17 tires for 850.00 firm
(4) Brand new ford racing 17 x 8" anthracite bullet wheels for 94 thru 04 mustangs new in the boxes for 650.00 firm
(4) Brand new factory ford take off 17 x 8" anthracite bullet wheels for 94 thru 04 mustangs in great condition with like new 225/50/17 tires for 950.00 firm
(4) 17 x 8" anthracite bullet wheels for 94 thru 04 mustangs in good condition with 245/45/17 tires for 700.00 firm
(4) 15 x 7" 4 lug turbines in great condition with new tires for 400.00
(3) sets of 16 x 7" 4 lug silver ponies in good condition with decent tires for 400.00 each set
(2) sets of 16 x 7" 4 lug silver ponies in good condition with good tires for 650.00 each set
16 x 7" 4 lug silver ponies in good condition with decent front tires and mickey thompson et streets 28 x 11.50 x 16 rears with 3 passes all for 650.00
(4) 16 x 7" 4 lug black powder coated ponies like new with new 225/60/16 tires all for 650.00 firm
4 lug pony wheels with new front tires and new hoosier 28 x 10 slicks on rear all for 850.00
4 lug weld wheels with front skinnys with like new tires and 10" rears with mickey thompson 28x10.50 slicks that are in good condition all for 1,300.00 firm
(2)17 x 8" 5 lug chrome 1997 gt wheels with flaking and pitting for 100.00
Skinny kid manual brake kit for 94-04 mustang part#skrc-mcy194upbbspecial brand new in the box for 300.00 cash
Caster camber plates for sn95 used for 125.00
Upr bump steer kit for foxbody with power rack new for 140.00
Kyb shocks and struts for a foxbody like new for 150.00
(2) sets of Hpm megabite sr adj lower control arms in good condition for 250.00 a set
(2) sets of Upr adj lowers like new for 175.00 a set
(1) set of Southside lower control arms used for 125.00 a set
Black tubular uppers with solid bushings for 125.00
bbk blue upper control arms like new for 75.00
silver solid upper control arms in good condition for 100.00
Qa1 10-150 coil over springs like new for 75.00
eibach 278246 rear springs like new for 80.00
eibach rear drag launch springs without bag for 100.00
eibach front drag launch springs for 75.00
bbk 2501 1 1/2" front springs brand new for 100.00
Steeda Double Hook Quadrant for 50.00
double hook quad for 50.00
(4) adjustable clutch cables almost new for 30.00 each
set of used kb pistons for a 345 cu inch motor for 150.00
stock efi distributers for 87 thru 93 used 75.00 each
BBk 76 mm.mass air meter for 94/95 mustang calibrated for 19# injectors like new for 175.00
(2)Pro-m 75mm.mass air meter for 19# injectors in good condition for 140.00 each
(2) C & L inlet pipes for 75.00 each used
(2) C & L inlet pipes for 100.00 each new
Pmas 75mm. mass air meter calibrated for 24# injectors new for 200.00
C & L tubes blue,yellow and clear 40.00 each
C&L 76 mm.maf for 19# injectors like new for 165.00
(3) C & L 76 mm.mass air meters calibrated for 24#injectors for 165.00 each new
C & L 76 mm. mass air meter calibrated for 36# injectors for 165.00 new
(2) C & L 76 mm. mass air meters calibrated for 30# injectors for 165.00 each new
pro-m 80mm.mass air meter calibrated for 55# injectors in good condition for 200.00
Sct 90 mm. big air mass air meter for 200.00
computer for 94/95 mustang gt for 300.00 with core each
engine harness for 94/95 mustang gt for 150.00
speed density harness for 175.00
(2) mass air computers for mustangs in good condition for 400.00 with core each
(6) 89 thru 93 mustang computer harness 250.00 each
(6) 89 thru 93 mustang engine harness 100.00 each
(3) Ford motorsport clutch and pressure plate setups for 5.0 mustang used for 100.00 each
(1) king cobra clutch and pressure plate setup for 5.0 mustang used with low miles for 150.00
Ram 10 1/2" 10 spline 900 clutch kit with 200 miles on it for 250.00
Flowmaster 2 1/2" base silver tailpipes in decent condition for 100.00
Bbk x pipe for fox body with long tube headers and dynomax mufflers like new for 300.00(pickup only)
3" x pipe for long tube headers with flowmasters for 300.00(pickup only)
(2) Bbk h pipe with flowmasters with turn downs all for longtube setups for 300.00 each set(pickup only)
Mac 2 1/2" h pipe for longtubes like new for 150.00
2 1/2" h pipe for shorty headers like new but needs 1 piece welded for 150.00
Bbk h pipe for long tube headers on a 99-04 gt like new for 150.00
magnaflow round mufflers for 125.00
dynomax long mufflers used for 150.00
(2)Flowmaster 3 chamber mufflers like new for 150.00 each set
Flowmaster 1" race knockoffs brand new for 130.00
flowmaster longs 2 1/2" in and out for 125.00
(2) sets of bbk shorty 1 5/8 headers for 302 in good condition for 175.00 a set
(1) set of bbk equal length 1 5/8 headers for 302 in good condition for 175.00
(1) set of Mac equal length shorty 1 5/8 headers for 87/93 gt in decent condition for 150.00
(1) set of bbk shorty headers for a 94/95 mustang like new for 175.00
Ford motorsport 351 swap 1 5/8 headers for 87/95 mustang in good condition for 250.00
1 5/8 shorty headers for 94/95 gt new black in color for 140.00
1 set of ceramic coated 1 5/8 longtube headers for 79 thru 95 mustangs used for 200.00( 2 bent tubes)
1 set of coated 1 5/8 longtube mac brand headers all new for 79 thru 95 mustangs for 650.00
(3)sets of 4:10 gears for 8.8 used 140.00 each
(1)set of 3:90 gears for 8.8 used 190.00 each
(1)set of 3:73 gears for 8.8 used 140.00 each
(4) sets of brand new ford racing 3:73 gears for 8.8 190.00 each
1 set of 3:73 gears for 9 3/4 used for 125.00
(2) sets of used 3:55 gears for 8.8 140.00 each
1 set of richmond 3:55 gears new for 190.00
1 set of brand new ford racing 3:55 gears for 8.8 190.00 each
1 set of used 3:27 gears for 8.8 140.00
Ford racing ring and pinion install kit part #4210-B2 new for 125.00
(1) 31 spline t-lock carrier for 8.8 rearend used for 200.00
(1) 31 spline t-lock carrier for 8.8 rearend with carbon fiber clutches used for 250.00
moser mini spool for a 8.8 new for 100.00
(2) complete drum to drum stock 8.8 rearends for foxbody mustang for 850.00 each
(1) complete drum to drum 8.8 rearends for foxbody mustang with 3:73 gears for 950.00 each
1 complete 4 lug built 8.8 rearend for foxbody consist of 35 spline strange axles with long studs,spool,3:27 gears,c clip eliminators and a girdle cover all for 1,800.00 firm
1 complete 4 lug built 8.8 rearend consist of 31 spline moiser axles,spool,4:10 gears,and c clip eliminators all for 1,800.00 firm
1 complete 4 lug built 8.8 rearend for foxbody consist of 31 spline axles with long studs(needs 1 replaced),31 spline locker spider gears welded,4:10 gears,and poly bushings all for 950.00
1 complete 5 lug 8.8 rearend for foxbody consist of 5 lug axles,auburn unit,3:27 gears,and disk brakes all for 1,000.00 firm
1 8.8 disc brake rearend for 99 thru 04 mustang with 3:27 gears,gt calipers and rotors (needs pinion bearing replaced) all for 750.00
1 8.8 disc brake rearend for 99 thru 04 mustang with 3:73 gears and gt brakes and calipers all for 950.00
Nos sniper kit for carb complete 6 months old for 400.00
Nos cheater kit minus main line and bottle for 350.00
Nos bigshot plate kit with TNT solenoids minus mainline and bottle for 350.00
(4) efi wet setups minus bottle for 285.00 each
Nx part #20421-10 proton efi nos kit like new for 400.00
1 nos dry nitrous setup minus bottle for 285.00
compucar dry nitrous setup minus bottle for 285.00
(2) new #6 nitrous main lines for 85.00 each
(2) Nos cheater plates for 90.00 each
Nos proshot solenoid used for 100.00
nos 05115 dry kit all brand new for 650.00 firm
nos 05001 powershot carb wet kit all brand new for 450.00
(2) 2 5/8 manual auto meter sport comp black face fuel pressure gauges 0 to 15psi 1 used for 35.00 and 1 new for 50.00
(1) 2 5/8 manual auto meter pro comp ultra lite silver face fuel pressure gauge 0 to 15 psi used for 60.00
(1) 2 1/16 white face lunar series manual nitrous pressure gauge for 50.00(back light doesn't work)
(1) used 2 5/8 electric but missing sender auto meter pro comp black face fuel pressure 0-15 psi gauge for 35.00
(1) used 2 1/16 electric but missing sender auto meter sport comp black face oil pressure gauge 0-100 psi for 35.00
(1) used 2 5/8 electric but missing sender auto meter sport comp black face oil pressure gauge for 35.00
(1) used sunpro white face 2 1/16 water temp gauge for 40.00
Auto Gage black 0-8000 rpm monster tach with shift light all like new for 200.00
Auto Gage black face 0-10,000 rpm monster tach with shift light like new for 200.00
Auto Gage silver face 0-10,000 rpm monster tach with shift light like new for 200.00
Auto Gage black face 0-10,000 rpm monster tach with shift light thats missing the recall button otherwise like new for 150.00
(2) 2 gauge pods for mustangs used for 50.00 each
I may consider shipping small items only but shipping and PayPal fees will apply, Pickup in Barnwell s.c.29812 is preferred 803-300-0855 (please call or text between 9am and 9pm for faster response and only ask for pics if serious about buying i stay very busy with my full time job)thanks
nastymustang is offline   Reply With Quote
Old 03-12-2023, 08:29 AM   #2
nastymustang
Updated
