Go Back   HorsepowerJunkies.com Forums > Off Topic and More > Junkies Den
Thread Tools Search this Thread Display Modes
Old 12-07-2020, 04:09 PM   #1
Hot Rod em all
Lightbulb What in the actual....... Charger
Haha. Enjoy.
Old 12-07-2020, 04:54 PM   #2
HotSoup
HotSoup's Avatar
HotSoup has disabled reputation
All those Mustangs, he didn't want to do a trade for the Cobra?
Whats in store, hellcat swap?
HotSoup is offline   Reply With Quote
Old 12-07-2020, 06:13 PM   #3
great looking car!
Old 12-08-2020, 06:59 AM   #4
confused
Fuquay Vagina
confused's Avatar
confused is actually making some sense.confused is actually making some sense.
Bullit clone
Old and slow
confused is offline   Reply With Quote
Old 12-08-2020, 10:06 AM   #5
The Flying Clutchman
Serious Poster
The Flying Clutchman's Avatar
The Flying Clutchman is without a doubt too mature for this placeThe Flying Clutchman is without a doubt too mature for this placeThe Flying Clutchman is without a doubt too mature for this placeThe Flying Clutchman is without a doubt too mature for this placeThe Flying Clutchman is without a doubt too mature for this placeThe Flying Clutchman is without a doubt too mature for this placeThe Flying Clutchman is without a doubt too mature for this placeThe Flying Clutchman is without a doubt too mature for this placeThe Flying Clutchman is without a doubt too mature for this placeThe Flying Clutchman is without a doubt too mature for this placeThe Flying Clutchman is without a doubt too mature for this place
Gen III Hemi swap?
1969 AMX
1970 Torino Squire Barra swap
1980 turbo Pinto wagon
1971 Chevelle SS
Real men drive terrible cars and we like it
The Flying Clutchman is offline   Reply With Quote
Old 12-09-2020, 08:01 PM   #6
Hot Rod em all
Old 03-05-2021, 09:40 AM   #7
Hot Rod em all
Haven't posted in this thread in a minute.
Old 03-05-2021, 10:29 AM   #8
nice
Old 03-05-2021, 10:39 AM   #9
One of the great body styles to come out of the 1960s.
Old 05-21-2021, 09:13 AM   #10
Hot Rod em all
Quick recap -
I purchased my 68 Charger in December 2020 from the original owners.
The car was stock with the factory, manual drum brakes and original suspension.
The previous owners had upgraded the wheels from the factory 14" to a set of American Racing VN5155765 wheels in 15" x 7" and a set of 235-60-15 tires.
The car rode very soft and the rear leafs had started to sag, to the point the front end was alot higher than the rear.
So far I have replaced the rear leaf springs (1"lower) and shocks.
I installed the Hotchkis TVS (total vehicle system) which has the Sport Leaf Springs and shackles, in addition to the Fox 1.5 Shocks.
Shocks - https://www.hotchkis.net/product/hot...8&md=287&sm=20
Leaf Springs - https://www.hotchkis.net/product/196...8&md=287&sm=20
For the front I am using the Fox 1.5 shocks.
However I decided to use the QA1 upper control arms - P/N 52305 - https://www.summitracing.com/parts/qa1-52305
I also have the QA1 tie rod sleeve upgrade - P/N 52325 - https://www.summitracing.com/parts/q...rger/year/1968
I also lowered the front torsion bars to give the car a lower front end so it didn't sit higher than the rear.
After these simple mods, the car handled much better and the ride height looked better.
Old 05-21-2021, 09:14 AM   #11
Hot Rod em all
As you know, I am a mustang guy so that means I have quite a few sets of wheels laying around.
One set in particular is my Mach 1 wheels that are 18x9" front and 18x10.5" rear.
These have a 26mm and 6.1 backspace (front) and a 27mm and 6.75 backspace (rear). They also have a 70.5mm hub size.
The tires are Toyo T1 275-35-18 front and Toyo R888 305-35-18 rear.
Being somewhat of an old-school look, I decided to fit them onto the 68.
First problem is the hub size on the Charger is a little over 71.5mm. It's very close, but unfortunately the mustang 70.5mm hub would not clear it properly and allow the wheels to sit flush.
Next problem was the backspace was too much and the wheels hit the suspension and brake components.
A solution was to install wheel spacers to give me a little more clearance and let the wheels fit.
I had a set of 2" spacers and while it worked, it pushed the rear tires too close to the outer fender lip. I was concerned that when the suspension moved, it would cut the outer sidewall of the tire.
Next I ordered and installed a 1" set of spacers. This fit much better and gave plenty of clearance. In reality I think a 1.25 spacer would be perfect.
However the 1" give me plenty of inside clearance to the inner fender well and the leaf springs.
This is with the 2" spacer. You can see how close the outer sidewall is to the fender lip.
This is with the 1" spacer. It fits much better and no chance to damage the tire outer sidewall.
Car is still under upgrades now so no pictures on the ground.
I am waiting on my disc brake conversion from Doctor Diff to arrive (next week).
Old 05-21-2021, 11:20 AM   #12
confused
Fuquay Vagina
confused's Avatar
Modern day magnum 500 look.Looks good!
Old and slow
Old 05-21-2021, 12:52 PM   #13
wow looks great!
Old 05-21-2021, 02:18 PM   #14
Lookin good man! Are you getting new front spindles - and most importantly - are they drop spindles?
Old 05-24-2021, 08:37 AM   #15
Hot Rod em all
Should be getting everything needed for conversion. Here's the site -
https://www.doctordiff.com/front-dis...-knuckles.html
And here's a video so far -
Old 05-24-2021, 11:38 AM   #16
Hot Rod em all
Old 05-24-2021, 04:54 PM   #17
Nice
Old 05-27-2021, 11:33 AM   #18
Hot Rod em all
Been working on upgrading the front drum brakes to discs.
A company called Doctor Diff https://www.doctordiff.com/front-dis...-knuckles.html - Makes a kit just for this.
I also added QA1 upper control arms and tie rod adjuster sleeves.
Next I put new MOOG ball joints and tie rod ends on it.
Hoping to finish this up for the weekend.
Old 05-31-2021, 09:03 AM   #19
Hot Rod em all
Got the brakes and suspension completed and had the front end alignment done.
Also my buddy Mike at PhantomBlackPhotography (from Instagram) did a photo shoot yesterday.
He has a 2019 Sublime Charger.
A few low rez pics are from my cell phone, the high quality stuff is all his. LOL.
Old 05-31-2021, 09:31 AM   #20
Excellent photography.
Old 05-31-2021, 05:00 PM   #21
Hot Rod em all
Old 06-03-2021, 05:50 PM   #22
Great pics!
Car looks fantastic!
Old 08-17-2021, 08:28 AM   #23
Hot Rod em all
So did a thing over the weekend............ bought another car.
Video on my YouTube page.
Old 08-17-2021, 01:43 PM   #24
doing a drivetrain swap?
Old 08-22-2021, 02:14 PM   #25
Hot Rod em all
Got the ScrapTona all loaded up and ready to go to somebody new! Haha.
If you are in need of a parts car in the Raleigh, NC area, let me know.
It still has some good parts on it including fuel tank/pumps, dash/cluster/gauges, passenger side doors/glass/window motors/door panels/trim, hood, trunk lid/spoiler, taillights, headlights, rear differential, etc.
Search this Thread:
Advanced Search
