Old 01-26-2022, 09:08 AM   #201
picking son up from school yesterday and something let go transmission or clutch? not sure yet. I think I'll save up for a Coan Racing automatic transmission ive had very good luck with them in the past. Hopefully I can climb under there this Saturday and find the problem. If its the clutch I will probably fix for now but its a new clutch rated at 1,000+ hp so.....
Old 01-26-2022, 03:26 PM   #202
Damn, that sucks! Your stuff just sounds a lot more expensive than mine. lol
Old 01-27-2022, 05:26 AM   #203
theheder
theheder's Avatar
theheder has no rep around here.
Those sticky tires in the snow must have hooked up and broke something
"Only those who will risk going too far can possibly find out how far one can go." - T. S. Eliot
theheder is offline   Reply With Quote
Old 02-04-2022, 12:26 PM   #204
yoke stripped & twisted the splines on the ne pinion gear? OMG ordered ne pinion bearings, gears, seal & Yoke all from Moser. there goes another $500
Old 02-05-2022, 07:43 AM   #205
HotSoup
HotSoup's Avatar
HotSoup has disabled reputation
I thought all that was new Mike?
HotSoup is offline   Reply With Quote
Old 02-06-2022, 10:01 AM   #206
Did the pinion yoke come pre installed?
Sent from my SM-G975U using Tapatalk
Old 02-08-2022, 08:38 AM   #207
yes its all new I'm going with I messed up the setup and the pinion became loose after i started driving entire rear is out on a bench so I can get to things better this time. new stuff should be here tomorrow
Old 02-12-2022, 02:22 PM   #208
ALL BACK TOGETHER
https://scontent-atl3-1.xx.fbcdn.net...sA&oe=620C6A55
Old 02-22-2022, 05:00 PM   #209
ok its together fires up idles good seems to drive great til about 15-20% tps then falls on its face. I just data logged but havent looked at it yet.
Old 02-24-2022, 05:21 PM   #210
I need a DAMN LT-1 ignition system expert over here ASAP!!!!!!! and money is of no concern here cause I dont have any of that either
Old 02-24-2022, 06:49 PM   #211
theheder
theheder's Avatar
Did you check or replace the infamous Optispark?
They are are notorious failure posts in those cars.
Old 02-24-2022, 08:04 PM   #212
YES $1300 FOR THE msd kit PRO BILLET DISTRIBUTOR, 7al BOX, msd COIL, MSD WIRES, NEW WIRE HARNESS.
JEGS
MSD LT1 Ignition Full Kit 1995-97 F-Body
Part Number: 121-83811K
$1,285.13
Old 02-24-2022, 08:16 PM   #213
Fuel pressure good?
Old 02-24-2022, 08:22 PM   #214
I just ordered an ignition module to replace the cheap ass one on there
Old 02-25-2022, 10:22 AM   #215
MAF before or after the supercharger? Mine is currently before the supercharger Im installing a new one today and thinking about relocating between the throttle body and supercharger
Old 02-27-2022, 08:50 AM   #216
Strong Speed Works is super fast at turning out tunes! loading a new one now this thing just keeps running better. My entire issue was 8 loose bolts on the supercharger let it blow off boost.
Old 03-09-2022, 12:01 PM   #217
never ending shit!!!!! I stripped the oil pump drive gear couple weeks ago! had to tear the damn motor apart. Got back running now I need to look at the supercharger and find a damn boost leak.
Old 03-09-2022, 03:29 PM   #218
I feel ya... The new 3rd member for my Pinto just shipped and should be here tomorrow. Took a month and a half
Old 03-11-2022, 08:22 PM   #219
well its back together and the blower makes a cool whistle noise it never made before. Revs smooth and the boost looks normal on the gauge. Cant test drive due to rain. I did notice a brand new belt in the blower and a JB performance Billet Impeller so it looks like someone did some work to it. replaced all the couplings and clamps on the boost side. Test drive and data log tomorrow. If this doesn't work.......Carb, intake and pro billet distributor! I know I can make that work
Old 03-13-2022, 10:41 AM   #220
25 Minute data log with a few WOT pulls @ 5psi and emailed it to STRONG SPEED WORKS , I need to get a camera mount in my car somewhere
Old 03-13-2022, 06:39 PM   #221
HotSoup
HotSoup's Avatar
Can get a ride when I get up that way to get that Lapua ammo from you?
Old 03-14-2022, 09:52 AM   #222
yeah
Old 03-14-2022, 09:54 AM   #223
https://youtu.be/cQxsNZ_EUP0
Old 03-14-2022, 06:50 PM   #224
had to start from scratch on the tune and data log today with the MAF off. hopefully I'll have a new tune tomorrow
Old 03-16-2022, 03:06 PM   #225
sounds mean!
12 bolt swap, ls1 swap > supercharged built lt1, LT WON, needsspraypaint, No Krylon no care, paintthensale
