#101 |
Stickers add almost 140 hp I have (2) ea 20 hp stickers
95 Kamero M6, Moser12, 358ci, Trick Flow heads, XFI 242/248, powedyne Blower |
#102 |
sounds great!
looks fast too!
Joel his: 1976 Olds Cutlass S hers: 1990 Chevy 454SS |
#103 |
it runs good! lol
#104 |
Man those Hoosiers look TIGHT!
Hope they don't expand much at the top end, lol They look great though! |
#105 |
swapped 3 plugs runs great??? Need to data log finish the tune. My track bar is on back order so I modified the factory sway bar to work so I can drive
#106 |
Nice work man.
74 Dodge Challenger 500 inch stroker - CAM ONLY 4L80E, ladder bars, 325-50 MT DR's - Full cage - Street Car! https://horsepowerjunkies.com/forums/...hlight=mock-up |
#107 |
THINK i FIGURED IT OUT USING "TUNER CATS" PROGRAM
ADD or Pull Timing 1. Tables a. Main Spark Advance vs. RPM vs MAP ( 800-4,000 RPM ) b. Extended Main Spark Advance vs. RPM vs MAP ( 4,000-7,000 RPM ) Use + or – to add or remove ( changes in .5 degree increments ) ADD or Pull Fuel 1. Tables a. MAF Sensor Calibration table 1 (1,500-3,999 RPM) b. MAF Sensor Calibration table 2 (4,000-6,599 RPM) c. MAF Sensor Calibration table 3 (6,600-9,000 RPM) Use + or – to add or remove ( changes in .1 gm/sec increments ) Example: If target is 11.3:1 AFR and current is 12.5:1 AFR ADD .11% If block says 94 gm/sec change to 104.4 gm/sec (change percentage across 4 blocks minimum to keep smooth curve )
#108 |
Installed new torque arm yesturday its ready to drive / tune now
#109 |
good to hear your getting the tuning figured out!
#110 |
data logged from 30 mph 2nd gear pulled to 6,500 let off. On the hit 11.3:1 AFR it was good to about 4,500 rpm then rose to 12:1 and steadilly rose to 13:1 @ 6,500 gonna try and add fuel from 4,500 to 7,000 and see if I can get it right
#111 |
Tuner Cats!!! I have not heard that one for years!
I used to use it on my old 95 Z28 back in 01 |
#112 |
Plenty of fuel pressure but at 6k it goes over 12:1. I can drive and enjoy just can’t shift over 6k. It will still rev to over 7k in a heartbeat but way too lean.
#113 | |
What's the injector duty cycle? If it's really high - you may need larger injectors.
#114 |
Im trying to find that
#115 |
#116 |
All clean
#117 |
I believe the injector pulse width is what you're looking for. Looks like it is stating the number for the right side and left side. I'm not sure what the units are for that number, but if it it is a percentage, then it would be 34.99 and 36.07%, which to me would seem like you have plenty more left in those injectors. However, that being said, it would be worth investigating what units those numbers are in so you can get a clearer picture of what's going on. If it's in ms (milliseconds) it could mean something totally different.
#118 |
ok I'll research
#119 |
What are you using to tell your AFR? Separate WB I'm assuming?
1985 Iroc 1986 Iroc 2009 G8 GT |
#120 |
yes seperate wideband where I took that snapshot im getting close to 12:1 then it goes up fast to 13.4ish at 7k RPM's
#121 |
Mike that looks like a bunch of timing on a blower car.
#122 |
I sent the data log to a tuner hopefully he will adjust timing and fuel or tell me what to do about injectors
#123 |
I haven't messed with Tunercats in years too! Think I still have an odb1 cable I'd made from back then as well. I used to scan with Datamaster, liked it's formatting better.
You can convert your pulsewidth to injector duty cycle using the formula below: (Pulsewidth * RPM) / 1200 = % Duty Cycle Assuming your pics are from the same data point this is what you get: (Pulsewidth * RPM) / 1200 = % Duty Cycle (34.99*5886)/1200=171.6% (36.07*5886)/1200=176.9% If that math is right, are you running the stock injectors on that thing?? I usually look @ the MAF g/s reading to give me a swag on the rwhp, yours is reading 468, if it's reading right, not bad. Think you'd be ok with 40-50lbhr injectors.
*Jeff* 02 s10 blazer 2wd, 4dr - L33 5.3L, Z06 cam/springs, 8.5" rear, 3.73s, built 4L60-E, 02 Z28 SS rims - SOLD Click here for build thread 64 Chevelle mordoor Malibu, red headed step foster child LQ4/T56 swap Click here for build thread |
#124 |
They are new Accel 30# injectors
that was a screenshot at 5,xxx rpm I turn it up to 7,200 https://www.holley.com/products/fuel...e/parts/150830
95 Kamero M6, Moser12, 358ci, Trick Flow heads, XFI 242/248, powedyne Blower Last edited by Mwilson; 05-18-2021 at 07:48 AM.. |
#125 |
Anyone have a reccomendation on injectors that fit this car?
Tags |
12 bolt swap, ls1 swap > supercharged built lt1, LT WON, needsspraypaint, No Krylon no care, paintthensale |
