Old 03-27-2016, 09:29 AM   #51
Originally Posted by DTPerformance View Post
Looks good man you going to keep sleeper look
Yeah I might do a cowl hood but that would be it.
Old 06-12-2016, 01:16 PM   #52
Well not much to add right now. Got the truck in the shop before my wife had the baby and got some accessories bolted up, under side done, and that's about it. Got it to where power is hooked up and I can sit in it and turn the key on with all the lights on lol.
Old 07-16-2016, 10:43 AM   #53
It runs!! I had to figure out why it had 3 cylinders had misfires and found that 3,5,and 6 had dead injectors. Got them in and its good!
https://youtu.be/UwN8HZUXocg
https://youtu.be/-H9c503-H08
Old 07-16-2016, 02:23 PM   #54
sounds good!
Old 05-30-2020, 07:00 PM   #55
So, a lot has happened with this truck. Had about 5k miles on the 4.3 I built and something broke. Had a dead cylinder. After finding high leak down in a few cylinders I pulled the valve covers. Had a broken Comp Cams double valve spring. Also I believe my high leak down was possibly from the injectors washing the rings out when first trying to get it running. I should of known better to trust those injectors after those years of sitting. The engine would also build up pressure in the cooling system very quick, which I found to be the #6 cylinder head bolts broke loose very easily. Not sure why, but when I installed them I did a few torque cycles of tighten, loosen. tighten, loosen, etc over a period of time. I decided instead of putting more money into the motor to do what I should have in the first place, LQ9 swap
As of now I got an '02 LQ9 that is being honed, SRP or Weisco pistons, bearings, LS9 head gaskets, ARP head bolts, and probably a BTR stage 2 truck cam. Trying to keep it fairly stock for now but I want to build it with longevity in mind. Heads are the stock 317's that will get a valve job and cleaning. I have all of Holley's LS swap parts for it and a Current Performance swap harness. I didn;t think it would take this long for the machine work as it has been there for about 11 months for a hone and balance the rotating asm..... I was planning to already be driving this.
I will go back through the 4.3 one day and maybe swap it into another truck with the Procharger setup and have some fun. My oldest has about 5 years before he starts driving so that should give me an excuse to get it back up.
Old 09-06-2020, 05:35 PM   #56
Finally got the 6.0 back from the machine shop in late July I think it was. I actually ended up picking up a 110k miles 4.3 from a guy that said it had a miss on #6 at idle but went away while driving. Rolled the dice as I thought it sounded like a valve and it was. Actually had a leaking valve on #4 and #6 cylinders. Machine shop said it would be about a month wait for a valve job, I picked up a newer set of heads that had the bolt down roller fulcrum rockers and bolted them on after checking the valves. re gasketed everything and a new GM timing cover. It is all in the truck now bolted up to the trans, accessories on, just need to finish the small things and get it on the road. Gonna take a little more time with the 6.0 swap. Added some pics of the broken valve spring from the other motor. Also found that the valve tips were chewed up a little. Heads were setup by the machine shop and I feel like I measured the pushrods correctly. You can see the rockers are not centered on the valve tips. Next time I will just go with some self aligning rockers.
Old 09-06-2020, 05:43 PM   #57
This is my long term goal for the truck. It is crazy what people want for these used when you can buy them new with a little wait time.
Sent from my SM-G975U using Tapatalk
Old 09-07-2020, 06:02 AM   #58
theheder
theheder's Avatar
theheder has no rep around here.
With the release of the 2650 the availability of used 1.9s has gone up alot. I sold mine and all the supporting mods when I went twin turbo in 2 days.
"Only those who will risk going too far can possibly find out how far one can go." - T. S. Eliot
theheder is offline   Reply With Quote
Old 09-07-2020, 07:01 AM   #59
Guy over on s10forum with a 2 door blazer broke into the 10s with a stock blower and ZL1 lid. If I can do the same , I will be happy.
Old 09-08-2020, 06:41 AM   #60
Hot Rod em all
Cool!
Old 10-01-2021, 07:05 PM   #61
damn badass just saw this
LSA, p1sc, procharger, s10
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
