Old 01-01-2015, 04:57 PM   #126
Stangalang87
Stangalang87's Avatar
Stangalang87 is without a doubt too mature for this placeStangalang87 is without a doubt too mature for this placeStangalang87 is without a doubt too mature for this placeStangalang87 is without a doubt too mature for this placeStangalang87 is without a doubt too mature for this place
Tried to get this to upload with the last post but something was going crazy with the link.
87 LX vert 347 T5-Sold
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Stangalang87 is offline   Reply With Quote
Old 01-02-2015, 06:04 PM   #127
Stangalang87
Went by to drop something off at Phillips and got a birthday surprise. He had the hood finish fit and dzus in. So now the front end is officially one piece, just needs some rivets and it will be finished up. He's starting on the column tonight and tomorrow after we get the kirkey mounted we'lol install the quick release hub.
Here's one of the radiator support with the clip off.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-03-2015, 04:06 PM   #128
Stangalang87
Got alittle more done today. We have the brake pedal back in, the column is mounted and the rag joint is finished, put a new passenger side door handle in I ripped off, got the kirkey mounted, got the shifter installed, and Removed the wing. I've been kinda torn about it, whether I like it or not. I wanted to modify it so it didn't sit so high but by the time I buy more supplies to change it and finish what was left plus my time in it I can just buy another one. So I think I'm ordering a strutless team Z wing on Monday. Now we're gonna make a list of what needs to be finished and start wrapping it up next week so it can make the move to my work to drop in the motor and trans. It's starting to look like a car again.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-04-2015, 05:33 PM   #129
Stangalang87
I didn't make it by Phillips to work tonight but I got some picture updates from him. He started filling the holes in the fire wall, he finished the heater box holes and a couple smaller holes on the drivers side.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-04-2015, 08:07 PM   #130
Stangalang87
Final trimming on the windshield and Bolted in. Got to pull it again to do the black out trim.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-05-2015, 07:09 PM   #131
Stangalang87
Not much accomplished tonight. I put in the correct bolts for the shocks, tossed the pinion Snubber, the big vibration damper off the diff, Phillip got some plates welded that tie the down bars into the strut towers which really stiffened the front up, and one side of the drivers side frame got boxed in from being cut to mini tub it. The anti roll should be here tomorrow so hopefully I'll have some install pics of the anti roll and tube braces. Also shooting for fitting he dash in tomorrow. I also threw the headlights in real quick and set it on the wheels to get a look at it. It's starting to look like a car again. Here's a couple pics.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-06-2015, 08:41 PM   #132
Stangalang87
Got the new ARB from UPR today. We got it in and finished along with the dash, drilled out all the nut certs from the old wing so we can start welding up the holes, added some more bars to the front to reinforce the radiator support. My radiator is at Johnny Gibbons shop getting some AN fitting welded on and getting a radiator support made. I haven't had a chance to meet him yet but he's been a lot of help with advice and parts on all this we've been doing at Phillips. Here's some progress pics from tonight.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-08-2015, 06:58 PM   #133
Stangalang87
Tonight I got the pleasure of removing 18 nut certs from the hatch that held the old wing in place and also knocked the paint down around all the factory wing holes so it can be welded up. I also cut the lips out of the rear wheel wells to clearance for the Tires. Hopefully we'll get the radiator and support installed tomorrow. I'll post pics when I get them.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-10-2015, 04:35 PM   #134
Stangalang87
Got the radiator and support back yesterday. Phillip got it welded in to the lower radiator support bar. The whole radiator and support is removable with a pull pin then you just lost it up. I threw the rear rotors on to see where the final rating place of the 275/60's was going to be after cutting the lips out of the wheel well it's close but I think we're good.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-10-2015, 06:37 PM   #135
Stangalang87
Fuel cell and battery box supports are in place, got some paint on the bars, gonna order a bulkhead and some other ScottRod parts tonight.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-12-2015, 09:07 PM   #136
Stangalang87
Getting close to being done at Phillips. The back floor is almost done, just have to paint and rivet it in to the angle brackets he made. The rear end is out to weld on the tube braces and weld up everything fully and give it all a coat of paint. The windshield is pulled to do the blackout and paint the cage, the wing finally showed up, picked up my water outlet from gibbons race cars, and we started to make an aluminum cover to go hinge to hinge on the firewall. I also ordered some tinted hatch lexan from Blake at Holcomb this afternoon. Should have a complete roller before too long.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-13-2015, 09:21 PM   #137
Stangalang87
Got the panel to cover the hood hinges and other random holes done tonight and riveted in along with everything finish welded on the rear end with some paint. We shaved the drivers wiper hole tonight also. The rear piece of floor is complete and we started building the bulkhead tonight. Also instead of welding the 20 something holes in the hatch Ron is hooking me up with an extra he has laying around. Here's a couple pics from tonight.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-15-2015, 05:42 AM   #138
Stangalang87
Last night we made some more progress. The floor is riveted in, Phillip built the bulkhead, and I started on the master cylinder. We also threw the new to me hatch on it with the fancy gas door. All that's left on the list (if nothing gets added) is put the rear end back in, install lexan front and rear, paint everything, weld the harness tabs, and finish boxing up the frame. Here's a couple pics from last night of the bulkhead.
Here's with the hatch closed.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-17-2015, 04:50 AM   #139
Stangalang87
We were at it till 1am. The harness tabs are welded, frame plates are finished, sanded every square inch of the inside of the car, threw some paint on the inside quarters/floor area, blacked out the edgers of the front lexan, and hit the bars with there first coat. Next step is the team z wing and out the lexan in and it's heading home.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-19-2015, 08:18 PM   #140
Stangalang87
Took a rest for the weekend. Got back on it tonight and installed my Team Z wing and the blackout lexan front windshield is siliconed and screwed in. There weren't any instructions on how to measure for a hatch car so after winging it the two middle brackets ended up a hair high. We're going to drop them down later. Got just a few more things to finish and hopefully get it home this week.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-20-2015, 06:40 PM   #141
jspook
wife made me do it
jspook's Avatar
jspook is without a doubt too mature for this placejspook is without a doubt too mature for this placejspook is without a doubt too mature for this placejspook is without a doubt too mature for this placejspook is without a doubt too mature for this placejspook is without a doubt too mature for this placejspook is without a doubt too mature for this placejspook is without a doubt too mature for this placejspook is without a doubt too mature for this placejspook is without a doubt too mature for this place
A lot of work go's into building a race car. Looks good to me.
jspook is offline   Reply With Quote
Old 01-21-2015, 04:19 AM   #142
Stangalang87
Thanks. It's wearing me out. We've put a lot of time in it lately.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-21-2015, 08:26 PM   #143
Stangalang87
Got the hatch lexan drilled and fit, taped, and blacked out. He says we're finishing his work Friday. Here's a couple pics from the lexan install.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-23-2015, 09:50 PM   #144
Stangalang87
Tonight was a good night. Finished the cowl panel, mounted the catch can bracket and can, mounted the rear lexan, and tomorrow he'll finish up the rear floor piece and it'll be ready to come home.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-24-2015, 07:03 AM   #145
FUKAZ28
FUKAZ28's Avatar
FUKAZ28 is without a doubt too mature for this placeFUKAZ28 is without a doubt too mature for this placeFUKAZ28 is without a doubt too mature for this placeFUKAZ28 is without a doubt too mature for this placeFUKAZ28 is without a doubt too mature for this placeFUKAZ28 is without a doubt too mature for this placeFUKAZ28 is without a doubt too mature for this place
Looks good. Any plans on painting it?
FUKAZ28 is offline   Reply With Quote
Old 01-24-2015, 07:27 AM   #146
Stangalang87
Thanks. Definitely going to paint it. Just maybe not this year. Until I get it running and going straight I'm gonna keep it partridge family style. Dad liked red cars so I want to do red, but I would rather have black so I'm thinking of doing two tone.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-24-2015, 07:46 AM   #147
Heater
Tastefully Sarcastic
Heater's Avatar
Heater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this place
Keep up the good work!
Originally Posted by NufNuffz28 View Post
Damn! Ford Motors are so awesome!
Heater is offline   Reply With Quote
Old 01-25-2015, 06:38 PM   #148
Stangalang87
Thanks, I'm gonna try. Once it leaves my buddy's house progress will slow down. I've got a baby coming March 3 so I've got to get as much done before then as possible, it'll be a hot minute before it gets worked on after he gets here.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-26-2015, 06:24 PM   #149
Stangalang87
Ran by tonight to discuss what night the cars coming home. We ended up welding on tabs for front end limiters, and I started on some work inside the fuel door. I'm using Anderson plugs for my charger in between runs so I made an aluminum panel for the vehicle side plug and I'm going to mount a 2 5/8" volt gauge above the plug. Just started tinkering with it tonight I'll end up finishing it at home. Phillip and Dilbert are going to work on the last piece of rear floor and riveting all the dzus fasteners on the hood. This weekend the two of them also dropped the brackets on the wing to make it for tighter to the hatch. Here's a couple pictures.
84 Mustang SVO
89 GT 418w Glide
08 F250 hauler
Old 01-26-2015, 07:00 PM   #150
Blk Death
Speed of dumb
Blk Death's Avatar
Blk Death is without a doubt too mature for this placeBlk Death is without a doubt too mature for this placeBlk Death is without a doubt too mature for this placeBlk Death is without a doubt too mature for this placeBlk Death is without a doubt too mature for this placeBlk Death is without a doubt too mature for this placeBlk Death is without a doubt too mature for this placeBlk Death is without a doubt too mature for this placeBlk Death is without a doubt too mature for this placeBlk Death is without a doubt too mature for this placeBlk Death is without a doubt too mature for this place
Ive been following this since the beginning, doing an awesome job!
"I come in peace. I didn't bring artillery. But I'm pleading with you, with tears in my eyes, if you fuck with me, I'll kill you all"
General James Mattis
Blk Death is offline   Reply With Quote
