Old 11-17-2020, 09:46 AM   #1
Vehicle 111. 67 GTO anyone?
Just took this one in trade this weekend.
67 with a 428. Not perfect, but a great daily
Going to be a fun one.
Old 11-17-2020, 12:26 PM   #2
confused
Fuquay Vagina
confused's Avatar
confused is actually making some sense.confused is actually making some sense.
Now that is HOT!
Old and slow
confused is offline   Reply With Quote
Old 11-17-2020, 01:30 PM   #3
looks like a pretty nice car!
Old 11-18-2020, 06:04 AM   #4
TTSALEEN
Terminator ur G8
TTSALEEN's Avatar
TTSALEEN is without a doubt too mature for this placeTTSALEEN is without a doubt too mature for this placeTTSALEEN is without a doubt too mature for this placeTTSALEEN is without a doubt too mature for this placeTTSALEEN is without a doubt too mature for this placeTTSALEEN is without a doubt too mature for this placeTTSALEEN is without a doubt too mature for this place
Saawweettt!
TTSALEEN is offline   Reply With Quote
Old 11-18-2020, 09:27 AM   #5
My god man, how in the hell are you doing this? You could literally work a trade all the way up to an F40 or something if you wanted..
Old 11-18-2020, 09:32 AM   #6
Lol.. it's not all it's made out to be, but just in this trade run with even swaps.
Bought 55 Chevy 3100 roller
Built it
Traded it for the 1930 Model A
did a little work to that, but not a ton.
Traded that for the 69 C10
didn't do much to that.
Traded that for the 56 210
Did a ton to that one.
Traded that for this.
This one is my favorite driving car out of all of them by far!
And that 428 (433.. .030 over, lol) has a ton of torque!
Old 11-18-2020, 03:25 PM   #7
.......and another killer score man! You're on a roll!
Old 12-15-2020, 05:53 AM   #8
Ok, so in the 3-4 weeks since getting the car I have been busy.
I replaced the fuel tank with a Tanks INC EFI tank with in tank pump, FITech fuel injection, fuel lines.
Did a front disc brake conversion with new brake lines, master cylinder, proportioning valve. New fan.
New, transmission filter, pan gasket, lines, and dip stick, and mount.
Power steering box o-ring, new gauges, and some correct 428 fender callouts.
Last but not least, new front tires. These were dry rotted and split bad.
She is a great driver now
Old 12-15-2020, 06:15 PM   #9
Originally Posted by Blue70 View Post
Old 12-16-2020, 08:09 AM   #10
Kickass man!
Old 12-17-2020, 07:26 AM   #11
Just watch the vent line on that tank. I can't get over 3/4 full without having fuel come out of the vent. Need to get off my ass and install a burp tank or larger vent lines to allow fumes past the fuel to keep them from carrying fuel all the way out.
Old 12-18-2020, 11:49 AM   #12
So far so good. I have had over 3/4 in it.
There are 3 vents in mine.
One at the fuel pump, one in the tank right beside it.
They give you a Y fitting to tie these two together, then they give you a roll over valve that you have to mount as high as you can above the tank.
Mine is mounted as high as I could get by the upper shock mounts.
The 3rd vent is in the filler neck, that one ties into the stock rubber line that was in the same spot on the original tank.
I have had about 7/8 full so far.
Old 04-07-2021, 12:27 PM   #13
Took the wheels and tires I bought for the 53 and put them on the Pontiac...
I think I like them better here...
Old 04-07-2021, 12:54 PM   #14
very nice!
95 Kamero M6 4.56 gear, 358ci, Trick Flow heads, XFI 242/248, powedyne Blower
Old 04-08-2021, 02:42 PM   #15
Yes they look great on the Pontiac!
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
