Please visit our local sponsor: |
Thread Tools | Display Modes |
#76 |
#77 |
New radiator installed
#78 |
Got her good to go just in time for the Collector Autofest.
#79 |
Have not updated in a while. Since last post I had to replace the carb. My old carb had a stick float and was pouring gas everywhere. Had to get towed home from the downtown wake Forrest show. Anyway I was going to rebuild it but whoever previously rebuilt it used some sort of adhesive that reacted with the metal. It's garbage. I went with a new Holley 750 cfm. It's running great.
#80 |
Looks good man, time for some long tubes on that Ol girl.
*Jeff* 02 s10 blazer 2wd, 4dr - L33 5.3L, Z06 cam/springs, 8.5" rear, 3.73s, built 4L60-E, 02 Z28 SS rims - SOLD Click here for build thread 64 Chevelle mordoor Malibu, red headed step foster child LQ4/T56 swap Click here for build thread |
#81 |
Since going with the aluminum radiator my fan has been hitting the shroud. Turns out I have a bigger fan then that shroud can really hold. Ac cars had a bigger radiator and bigger fan/ shroud. Well my car is a non ac car and has the smaller radiator and shroud but the bigger fan. Have no clue how the previous owner had that shroud on so it would hit the fan. Anyway ordered the correct fan, just have to install it.
#82 |
#83 |
#84 |
still lookin' good!
Joel his: 1976 Olds Cutlass S hers: 1990 Chevy 454SS |
#85 |
#86 |
Glad to hear it!
Mind me asking what your wash procedure is? I've had to switch to using quick detailer / microfiber towels as the rust is coming on strong.
#87 | |
https://www.amazon.com/Optimum-NR201.../dp/B00D8DR0AO |
#88 |
Thank you!
#89 |
![]() Update: the 455 has a bad cylinder, the number 6 cylinder has pretty significant damage to cylinder wall from possibly piston ring. Plan is to pull the motor and get it bored out and rebuild it. Honestly the engine is extremely clean except cylinder 6. I thought about putting a ls in it however you just don’t see a lot of 455s and I’m probably going to put a big cam in it and roll with this one. Had it 5 years on an unknown build I’m not sad about it. Pretty excited! Last edited by fast?yea; 04-18-2020 at 03:02 PM.. |
#90 |
Hot Rod em all
Wow. Nice update. 455 ftw.
#91 |
#92 |
![]() ![]() ![]() ![]() She’s alive again! Driving damn good. 455 bored .30 over. Hydraulic roller cam, hydraulic roller rockers, adjustable valve train. Sent from my iPhone using Tapatalk |
#93 |
Badass!
95 Kamero M6, Moser12, 358ci, Trick Flow heads, XFI 242/248, powedyne Blower |
#94 |
Nice man!
74 Dodge Challenger 500 inch stroker - CAM ONLY 4L80E, ladder bars, 325-50 MT DR's - Full cage - Street Car! https://horsepowerjunkies.com/forums/...hlight=mock-up |
#95 |
![]() Fan shroud is on. Going to cut a hole in a flat hood I got and putting hilborn scoop on eventually. Hood needs some body work. Sent from my iPhone using Tapatalk |
#96 |
Did you get the engine work done? What all did you get into?
#97 |
good to see it back on the road and still Pontiac powered.
#98 |
Yes, got it bored out .30 over because had some wall damage in cylinder number 7. All new valve train, roller cam, stock polished crank, new pistons. I had a machine shop do the machine work but the engine was built by me and my buddy. She’s a torque monster. Sent from my iPhone using Tapatalk |
#99 |
#100 |
nice, no video with a sound clip
