Old 10-27-2009, 07:39 AM   #1
RedLS6
RoadRacer
RedLS6's Avatar
RedLS6 is without a doubt too mature for this placeRedLS6 is without a doubt too mature for this placeRedLS6 is without a doubt too mature for this placeRedLS6 is without a doubt too mature for this placeRedLS6 is without a doubt too mature for this placeRedLS6 is without a doubt too mature for this placeRedLS6 is without a doubt too mature for this placeRedLS6 is without a doubt too mature for this placeRedLS6 is without a doubt too mature for this placeRedLS6 is without a doubt too mature for this place
? Ford Techs; Ticking noise from top-end of 5.4
Truck is a 2001 F-150 with the 5.4.
It has developed a loud ticking noise from the top of the engine (sounds like a lifter). The noise is present only when the motor is first started cold at idle, then goes away after a few minutes as it warms up.
What's the most likely problem .. Cam phaser, hydraulic lash adjuster? How involved of a fix?
2015 C7 Z06/Z07
2014 Jeep Grand Cherokee Hemi 4x4
2011 Silverado 6.2L 4x4
2002 Torch Red Z06
RedLS6 is offline   Reply With Quote
Old 10-27-2009, 07:50 AM   #2
DSM Turbos
DSM Turbos's Avatar
DSM Turbos is without a doubt too mature for this placeDSM Turbos is without a doubt too mature for this placeDSM Turbos is without a doubt too mature for this placeDSM Turbos is without a doubt too mature for this placeDSM Turbos is without a doubt too mature for this placeDSM Turbos is without a doubt too mature for this placeDSM Turbos is without a doubt too mature for this placeDSM Turbos is without a doubt too mature for this placeDSM Turbos is without a doubt too mature for this placeDSM Turbos is without a doubt too mature for this placeDSM Turbos is without a doubt too mature for this place
Not that it helps, but my Silverado does the same thing and has for the past 30k miles..
DSM Turbos is offline   Reply With Quote
Old 10-27-2009, 08:29 AM   #3
cptbimes
They call me the mastadon
cptbimes's Avatar
cptbimes is without a doubt too mature for this placecptbimes is without a doubt too mature for this placecptbimes is without a doubt too mature for this placecptbimes is without a doubt too mature for this placecptbimes is without a doubt too mature for this placecptbimes is without a doubt too mature for this place
PM lunchbox. I think his truck had this problem and I know he had the engine replaced.
That's good ol' GM piston slap/lifter tick
I see wat u did
cptbimes is offline   Reply With Quote
Old 10-27-2009, 09:15 AM   #4
silver412
silver412's Avatar
silver412 is a good little Junkie
I have seen three different things make similar noises on those engines. Timing chains stretched,chain tensioners & lifters. You need to isolate the area it's coming from to have a better idea how involved will depend on what the problem is. The lifters aren't hard to replace once the valve covers are off and the chain & tensioners are easy once the front cover is off. The hardest part is removing the necessary parts to get to everything. How many miles are on the engine? And what oil filter are you using? There has ben some concerns with cheap filters coming apart blocking oil passages in the heads.
silver412 is offline   Reply With Quote
Old 10-27-2009, 11:21 AM   #5
Heater
Tastefully Sarcastic
Heater's Avatar
Heater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this placeHeater is without a doubt too mature for this place
I ran into that problem when I would use a cheap oil filter.Read that if the filter didn't have a anti-drain back valve that the engine would raise hell at idle when first started; so now all I run are Motorcraft filters (820S) on it and no problems.
Heater is offline   Reply With Quote
Old 10-27-2009, 01:19 PM   #6
SVTCobra347
Cone Killer
SVTCobra347's Avatar
SVTCobra347 might have posted something useful at one timeSVTCobra347 might have posted something useful at one time
Yeah, Motorcraft or Wix filters, both have antidrainbacks..
I agree, chain tensioners, guides, or lifter.. most likely in the chains though. Supposed to be replaced at 100K miles..
1972 AMC Javelin AMX. 360, 291 heads, Comp Cam, Indy rockers, R4B intake, Holley Carb.
1968 AMC AMX 390/727, E-85 powered, 6.91 @ 98.7 mph.
SVTCobra347 is offline   Reply With Quote
Old 10-27-2009, 02:45 PM   #7
red95gtcoupe
red95gtcoupe's Avatar
red95gtcoupe is a good little Junkie
Spark plug about to blow out? Worth a check I guess.
red95gtcoupe is offline   Reply With Quote
Old 10-27-2009, 02:50 PM   #8
Turbo Pig
Vengeance
Turbo Pig's Avatar
Turbo Pig is without a doubt too mature for this placeTurbo Pig is without a doubt too mature for this placeTurbo Pig is without a doubt too mature for this placeTurbo Pig is without a doubt too mature for this placeTurbo Pig is without a doubt too mature for this placeTurbo Pig is without a doubt too mature for this placeTurbo Pig is without a doubt too mature for this placeTurbo Pig is without a doubt too mature for this placeTurbo Pig is without a doubt too mature for this placeTurbo Pig is without a doubt too mature for this placeTurbo Pig is without a doubt too mature for this place
Watch for plug blowout for sure.
Turbo Pig is offline   Reply With Quote
Old 10-27-2009, 06:36 PM   #9
RedLS6
RoadRacer
RedLS6's Avatar
Thx for the responses. Didn't know about the plug issue - checked, and the plugs are tight. The noise seems to be coming from the front top driver's side. No exhaust leaks, definitely not injector noise.
My filter has the adb valve.
It only makes the noise when it is below 50 degrees outside temp. The consensus over on f150.net is cam phaser/chain/lash adjuster.
Any good shop recommendations?
2015 C7 Z06/Z07
2002 Torch Red Z06
Old 10-27-2009, 06:45 PM   #10
TurboFiveOh
TurboFiveOh's Avatar
TurboFiveOh is a good little Junkie
i had a collapsed lifter on my 99 GT that made a bad ticking noise. seems like all 2 valve mod motors make random noises..i think most of the time its the valve train or timing stuff just wearing out.
TurboFiveOh is offline   Reply With Quote
Old 10-27-2009, 07:22 PM   #11
headhunter
headhunter's Avatar
headhunter has no rep around here.
do u use 5 w20 oil and their is a oil supply in the upper camcaps at the rear of the heads that will get stopped up . see this all the time,i run a shop myself,its a problem .
headhunter is offline   Reply With Quote
Old 10-27-2009, 07:43 PM   #12
Turbo Pig
Vengeance
Turbo Pig's Avatar
When I had a tick from the top of of a 4.6, it was a timing chain guide
Old 10-27-2009, 09:42 PM   #13
Poonstang
You rooka rike a robster!
Poonstang's Avatar
Poonstang is a good little Junkie
I had a similar tick in my 02 gt a long time ago. It ended up being a timing chain tensioner could not get enough pressure at idle to keep the guides tight. The noise would go away after a little throttle. Ended up having the chain, guides, and I think 2 tensioners replaced under extended warranty. That was $734 bucks to my warranty company minus my $100 deductible.
hope this helps.
DD Lightning w/scratches and fast food bags
-"There is a Ford guy somewhere with a sweaty face, covered in baby oil, beating off to a GM guy's comment comparing corvettes to the 2011 Mustang GT."
oh yeah... lol lol happy face happy face lol
Poonstang is offline   Reply With Quote
Old 10-29-2009, 09:10 AM   #14
1C BITTEN
1C BITTEN has no rep around here.
My 2002 did something similiar to what you're saying. About 2 weeks later it blew a spark plug out on the drivers side. I think at one time there was a TSB about 2000 or 01' 5.4 engines doing this. Hope this helps. Shannon
1C BITTEN is offline   Reply With Quote
Old 10-29-2009, 09:43 AM   #15
PsiTsi
In The Street
PsiTsi's Avatar
PsiTsi is a good little Junkie
My truck does this, everything pointed to the cam phasers. I think it costs about $1k for a shop to fix it. Using the wrong oil/filter is what causes it (what ford dealership told me). I have a 04 f150 5.4.
2004 f-150 5.4 XLT 4x4, Flowmaster, K&N, Hell Bent Steel level, 35'' Mickeys on 17" procomps
2002 z28 daily
'15 Durango R/T kid hauler
1970 c10 swb project 350/3 on the tree
PsiTsi is offline   Reply With Quote
Old 10-29-2009, 03:33 PM   #16
red95gtcoupe
No exhaust leaks
That is a plus. I had swiss cheese manifolds that caused mine to leak horribly. Damn Ohio roads. The studs like to snap in half when changing manifolds.
Old 10-29-2009, 03:50 PM   #17
03blkmach1
Seeking the High Life
03blkmach1's Avatar
03blkmach1 is a good little Junkie
just an fyi motorcraft is just a fancy purolator. Its actually a purolator to be exact. Just looks a little different.
03blkmach1 is offline   Reply With Quote
Old 10-29-2009, 05:01 PM   #18
toolman
toolman is a good little Junkie
Sounds like a lash adjuster. (lifter in an older engine). This job can be done without removing very much from the engine. It my try your patience but a set of "lifters" and a few gaskets is less than 2 hundred dollars about anywhere except for a dealership. This is about a 4 hour job. I've done several 4.6 and 5.4 and all have been trying but rewarding$$$$$.
toolman is offline   Reply With Quote
Old 10-29-2009, 05:54 PM   #19
SVTCobra347
Cone Killer
Only the PureOnes.. but usually if you look around you can find the Motorcraft cheaper than a PureOne..
NAPA Gold is a Wix but costs more.. and Wix is easy to find now that O'Reilly's exploded all over the state
I would agree it's likely a lash adjuster, but could still be in the chains.
Also easily could be the chains or tensioners. It could be a secondary effect of stretched chains.. sometimes the tensioner moves past the last "stop" and has to pump up every startup to tension the chains, and other times they simply won't stay pumped up.
Just do the long screwdriver test, if you find the noise is just below the valve cover in the timing cover area, be ready to buy chains, guides, and tensioners. If it's in the valve covers, look at the lash adjusters, a bad one will be easy to spot.
01 5.4's don't have cam phasers. They came out in '04 with the 3V 5.4 for trucks and 05 3V 4.6 for Mustangs.. and they are a little noisy even when working properly.
Old 10-29-2009, 06:29 PM   #20
RedLS6
RoadRacer
RedLS6's Avatar
Good info guys!
Long screwdriver test - I'm assuming you mean screwdriver against block? I've been ready to put my stethoscope on it every morning this week, but with the weather being warm, the truck has not made the noise.
No cam phasers .... doh. I guess I can eliminate that
2015 C7 Z06/Z07
2002 Torch Red Z06
Old 10-29-2009, 07:20 PM   #21
SVTCobra347
Cone Killer
Yep I mean screwdriver against the block.. not everyone has a stethoscope (or at least one they're willing to smear around an engine lol)
Old 03-07-2011, 11:59 AM   #22
z1kaw1975
Z1900MAN
z1kaw1975 must be letting Dr. Rockwell use their screen name
I had the same problem; replaced the passenger side exhaust manifold, studs, gasket and nuts! FIXED IT!!!
HOPE THAT HELPS!!!
z1kaw1975 is offline   Reply With Quote
Old 03-07-2011, 12:39 PM   #23
SETOMPK
Sore Loser!!!
SETOMPK's Avatar
SETOMPK is a good little Junkie
I hope its fixed because this thread was started in 09!
Fuckin me? Now I'm Fuckin you LIL HO!!!
SETOMPK is offline   Reply With Quote
n00bDugUpOldThread
