Old 10-10-2009, 06:34 PM   #1
Quick69
HPJ's official car whore
Quick69's Avatar
Quick69 might have posted something useful at one timeQuick69 might have posted something useful at one time
Low oil pressure in a new Chevy truck
A friend of mine bought a 2009 2500 series silverado and the oil pressure reads low. I'm pretty sure its a 6.0L and he was wondering if this is common. He also wondered if there is a spring that can be swapped out in the oil pump to increase pressure.
http://www.horsepowerjunkies.com/forums/signaturepics/sigpic620_4.gif
haulin with the A/C on
Quick69 is offline   Reply With Quote
Old 10-10-2009, 06:35 PM   #2
wyndzer
Slow Ride
wyndzer's Avatar
wyndzer is without a doubt too mature for this placewyndzer is without a doubt too mature for this placewyndzer is without a doubt too mature for this placewyndzer is without a doubt too mature for this placewyndzer is without a doubt too mature for this placewyndzer is without a doubt too mature for this placewyndzer is without a doubt too mature for this placewyndzer is without a doubt too mature for this placewyndzer is without a doubt too mature for this place
Alot of the new ones read 15-20 psi at idle, but should come up under power.
ǝɹnʇɐuƃıs ʎɯ uı pǝʇsǝɹǝʇuı ʎllɐǝɹ ǝɹɐ noʎ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
wyndzer is offline   Reply With Quote
Old 10-10-2009, 06:42 PM   #3
Quick69
Quick69's Avatar
it builds with rpm, just thought 15-20lbs was low
Old 10-10-2009, 07:03 PM   #4
Silver91Hatch
Silver91Hatch's Avatar
Silver91Hatch is without a doubt too mature for this placeSilver91Hatch is without a doubt too mature for this placeSilver91Hatch is without a doubt too mature for this placeSilver91Hatch is without a doubt too mature for this placeSilver91Hatch is without a doubt too mature for this placeSilver91Hatch is without a doubt too mature for this place
Warranty!!
Foxbodies:
1991 Silver 2.3 Hatch 5 Speed - 100% Stock
1991 Sonic Blue 5.0 Coupe SSP 5 Speed - 99% stock
"Some people without brains do a lot of talking" Scarecow - Wizard of Oz.
Silver91Hatch is offline   Reply With Quote
Old 10-10-2009, 07:43 PM   #5
02gmc5.3
02gmc5.3's Avatar
02gmc5.3 is actually making some sense.02gmc5.3 is actually making some sense.
That seems a little low for a new engine, my 02 still has over 40psi at hot idle with 195k miles.
02gmc5.3 is offline   Reply With Quote
Old 10-10-2009, 08:11 PM   #6
Although that is plenty at idle there is a bulliten out for these RPO Codes L76, L92, L9H, LC9, LH6, LH8, LS2, LS3, LS4, LS7 for low oil pressure. These are the aluminum blocks.
Old 10-10-2009, 08:14 PM   #7
Same here. My '00 has 115k and has never dipped below 40 psi.
Old 10-10-2009, 09:09 PM   #8
03blackgt
03blackgt's Avatar
03blackgt best poster evAr!!!!!!11103blackgt best poster evAr!!!!!!11103blackgt best poster evAr!!!!!!11103blackgt best poster evAr!!!!!!111
Ive put a few oil pumps in these, along with motors due to pump failures. The pumps are a real PITA, gotta pull front diff, oil pan and front cover. Id rather put a motor in one then a pump.
'13 Suburban LTZ 4x4
'04 Silverado LT Z71
'15 Can-Am outlander 500DPS
03blackgt is offline   Reply With Quote
Old 10-10-2009, 09:15 PM   #9
02gmc5.3
02gmc5.3's Avatar
Why not pull the engine out then change it?
Old 10-10-2009, 09:28 PM   #10
03blackgt
03blackgt's Avatar
6 of one, half a dozen of the other, know what I mean?
Old 10-10-2009, 09:32 PM   #11
03blackgt
03blackgt's Avatar
PIP4158B: Low Oil Pump Pressure Due To Seized Oil Pressure Relief Valve - (Dec 1, 2008)
Subject:Low Oil Pump Pressure due to Seized Oil Pressure Relief Valve
Models:2008-2009 Buick Lacrosse, Allure (Canada Only)
2007-2009 Cadillac Escalade
2007-2009 Chevrolet Avalanche, Silverado, Suburban, Tahoe, Trailblazer
2007-2008 Chevrolet Monte Carlo SS
2007-2009 Corvette, Impala SS
2009 Chevrolet Colorado
2007-2009 GMC Envoy, Sierra, Yukon
2009 GMC Canyon
2008-2009 Hummer H2
2008-2009 H3 Alpha
2008-2009 Pontiac Grand Prix GXP
2008-2009 Pontiac G8 GT
2007-2009 Saab 97x
with Aluminum Gen IV V8 Engine Block
(RPO Codes L76, L92, L9H, LC9, LH6, LH8, LS2, LS3, LS4, LS7)
This PI was superseded to update models and to clarify that the PI is referring to the oil pressure relief valve in the oil pump. Please discard PIP4158A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2214865&from=sm#ss1-2214865">Condition/Concern:
Some customers may complain of low oil pressure, no oil pressure, and/or engine noise. This may be the result of a sticking oil pump pressure relief valve. In some instances, the customer may experience this intermittently if the valve frees up when the engine cools down.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2214865&from=sm#ss2-2214865">Recommendation/Instructions:
If the SI diagnosis isolates low mechanical oil pressure, replace the oil pump, flush the oil cooler lines (if equipped), clean the inside of the oil pan, change the oil and filter, and re-evaluate the concern.
Notice: If an engine noise is noticed after replacing the oil pump, follow the SI diagnosis and repair the engine as necessary.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Old 10-10-2009, 09:55 PM   #12
02gmc5.3
02gmc5.3's Avatar
I know what you mean, it's gonna be a pain to change either way.
Old 10-10-2009, 09:56 PM   #13
I put a timing chain and gears in mine and I didnt have to pull the diff or oil pan, just real careful when I pulled the strainer tube out.
Old 10-10-2009, 10:11 PM   #14
z71
z71 has no rep around here.
low oil pressure
I have a 99 z71 with 102k and a tahoe with 25k they both keep about 40psi. I looked at a new chev this week in durham. Glad I didn't buy one. Sounds like member silver91hatch hit it on the head. (WARRANTY TIME)
z71 is offline   Reply With Quote
Old 10-11-2009, 01:42 AM   #15
1991stangcoupe
Blown331
1991stangcoupe's Avatar
1991stangcoupe has disabled reputation
not to jack the thread but it wouldnt happen if it had a oval around it, jk ha lol
1991stangcoupe is offline   Reply With Quote
Old 10-11-2009, 06:52 AM   #16
LS1-3RDGEN
LS1-3RDGEN's Avatar
LS1-3RDGEN better shape up!
2500 is not an aluminum block though so there should not be a problem with it. my truck reads 20 at idle and 40-50 under load
2014 2500HD duramax
2014 Malibu LT3 wife
1992 3000gt vr4
[/U]
LS1-3RDGEN is offline   Reply With Quote
Old 10-11-2009, 07:52 AM   #17
FoxOnJackstands
Rahbababababbabab
FoxOnJackstands's Avatar
FoxOnJackstands best poster evAr!!!!!!111FoxOnJackstands best poster evAr!!!!!!111FoxOnJackstands best poster evAr!!!!!!111FoxOnJackstands best poster evAr!!!!!!111
we drove a 2500 back from seattle with the oil pressure low. come to find out it was a bad sensor
FoxOnJackstands is offline   Reply With Quote
Old 10-11-2009, 12:06 PM   #18
03blackgt
03blackgt's Avatar
I dont see how its possible to get the pickup bolts out of the pump? Unless the older ones are different? Ive studied it pretty hard to try to shortcut it but couldnt see getting the lower of the two pickup bolt out of the pump.
Old 10-11-2009, 01:56 PM   #19
I only loosened the bolts a little to let it drop and used a flex head ratchet wrench to get to the bolt.
