Thread Tools Search this Thread Rate Thread Display Modes
Old 06-06-2010, 09:46 PM   #1
steve28529
steve28529's Avatar
steve28529 is a good little Junkie
Nitrous on a stock lt1
I have a 95 Z28 auto, and want to know if the stock pistons, rods, and such would hold up with a 75-100 shot? Thought about buying a compucar dry kit, but have turned into a bit of a skeptic regarding nitrous in general after watching youtube for about 30 minutes. I can't afford to spend a ton of money in a turbo or supercharger. My best time in the 1/8 stock is a 9.22 . Also thought about going with a gear change from the 2.73's to a 3.73 . Any suggestions on a cost effective nitrous alternative, or would nitrous be the best bang for the buck? And I don't mean "bang" literally lol.
steve28529 is online now   Reply With Quote
Old 06-06-2010, 09:55 PM   #2
blyon70
blyon70's Avatar
blyon70 has no rep around here.
try a wet shot. It is safer than a dry shot, but a the same rate its still nitrous. A dry shot is way to volatile especially with out a tune. Wet 75, U should be fine.
blyon70 is offline   Reply With Quote
Old 06-06-2010, 10:04 PM   #3
TransAm94
TransAm94's Avatar
TransAm94 has no rep around here.
Well almost everybody you talk to will tell you do it haha, but I've got an NX kit and still haven't put it on my car..
I really haven't had any experience personally with nitrous so I'll let other people tell you what they know. But I have heard that if you do it right, you won't have problems, its when you get greedy thats when you start blowing stuff up.
Basically get window switch, a colder plug and retard the timing some and you shouldn't have problems, thats about the "safest" way to run nitrous.
Good luck and let me know how it turns out, you might motivate me to throw my kit on haha.
TransAm94 is offline   Reply With Quote
Old 06-06-2010, 10:15 PM   #4
steve28529
steve28529's Avatar
Luck isn't one of my strong points...lol. But if I do decide to do it, I will definately let you know how it turns out.
Old 06-06-2010, 10:20 PM   #5
steve28529
steve28529's Avatar
Gotcha.... The wet shot has a solonoid for added fuel right? Is it a requirement to upgrade fuel pump or should the stock one be good enough for a small shot like a 75? I'm a nitrous newbie (hence the stupid questions).
Old 06-06-2010, 10:40 PM   #6
TransAm94
TransAm94's Avatar
LS1 tech has a real good write up on nitrous..
http://www.ls1tech.com/forums/nitrou...o-read-me.html
Old 06-07-2010, 06:12 AM   #7
98Motorsport3
Psycho
98Motorsport3's Avatar
98Motorsport3 might have posted something useful at one time
Send a message via AIM to 98Motorsport3
I had an lt1 so I can give you actual first hand experience.. My motor was stock from throttle body to oil pan. I had bolt ons, 3.73's a 2800 stall and we used a combo of pills that netted it about 125 whp... I wanna say a 150 nitrous jet with a 175 fuel jet.. it was an nx kit and I beat the ever living shit out of it.. sprayed probably a bottle a week or more sometimes with a 15lb bottle and she never skipped a beat. It's all in the tune. It went 7.55's on 17's with shittos.
Nitrous will be just fine on your car or any other car for that matter as long as you don't get greedy, and have a safe tune. Dont' know why everybody is so scared of it.
EDIT: I used a mallory 685 box (the best for lt1's) which allowed me to retard timing upon activation of the nitrous and had an adjustable window switch.
00 silverado ecsb 2/4 ltz20's and some goodies(Toy Hauler)
1999.5 Super Air Nautique bauce edition
98Motorsport3 is offline   Reply With Quote
Old 06-07-2010, 08:46 AM   #8
HITMAN
Fastest LS1 on Nitrous
HITMAN's Avatar
HITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this place
It will take a 150 on a stock motor no problem as long as you make sure its getting plenty of fuel and ignition is right. Tune it on the dyno and squirt the sh#@ out of that b#@ch
HITMAN is offline   Reply With Quote
Old 06-07-2010, 08:54 AM   #9
RJBAILEY84
Just a little LT1
RJBAILEY84's Avatar
RJBAILEY84 has no rep around here.
let me know which way you go steve... im waiting for a quote from RPM to run a spray set up on my car as well pretty much a stock bottom and stock heads... Ill let you know what they recommend to me as far as the kit.. Also as far as the tune... im 100% sure Ryan has the skills to make it preform at the safest level...Good Luck with it man and let me know what you decide...
95- Z28 LTX, 388 with AFR's and a little bump stick built by..
RJBAILEY84 is offline   Reply With Quote
Old 06-07-2010, 04:22 PM   #10
steve28529
steve28529's Avatar
Ok I will. I still want to get that stuff from you. Just give me a call when you get close to j-ville.
Old 06-07-2010, 04:39 PM   #11
Jayber
FuckerGotBooted
Jayber has disabled reputation
keep detonation out and it will take much more N2O
Jayber is offline   Reply With Quote
Old 06-07-2010, 05:01 PM   #12
steve28529
steve28529's Avatar
Cool, I'll keep that in mind too. Would I need to use 100+ octane or would 93 be good enough?
Old 06-07-2010, 05:03 PM   #13
98Motorsport3
Psycho
I used 93 ocatane.
Old 06-07-2010, 05:04 PM   #14
steve28529
steve28529's Avatar
If I could get mid to low 8's out of it, I'd shit myself with excitement.
Old 06-07-2010, 05:08 PM   #15
steve28529
steve28529's Avatar
I used 93 ocatane.
ok thanks. always wanted to try it... just needed some guidance in the right direction.
Old 06-08-2010, 04:08 AM   #16
RJBAILEY84
Just a little LT1
RJBAILEY84's Avatar
will do man..
Ill let you know what my car does with the new gears within the next week or so...
Old 06-08-2010, 05:42 AM   #17
Jayber
FuckerGotBooted
Your in Vanceboro get that lazy NCHorseplay to help you out with the tune. He doesnt have anything else to do.
Seriously Im sure Lee wouldnt mind helping you blow it up... I mean setting it up
Old 06-08-2010, 04:41 PM   #18
cptbimes
They call me the mastadon
cptbimes's Avatar
cptbimes is without a doubt too mature for this placecptbimes is without a doubt too mature for this placecptbimes is without a doubt too mature for this placecptbimes is without a doubt too mature for this placecptbimes is without a doubt too mature for this placecptbimes is without a doubt too mature for this place
Send a message via AIM to cptbimes
My shit from a few years back. Car sounded like shit but...
Went 7.56@88mph and 12.0@109 with consistent 1.56 60 ft's. The only mods I had were Yank 3600 stall, 3.73's, and a 75 wet nx kit with a pirrahna nozzle. Those Bogarts up front helped alot too on the short times and were good for wheels pullin action. I could have used a window switch though...(blew out the donkey dong on a backfire, lol). So after it burnt the maf wires off I needed another maf to get home. Luckily my good buddy LS1Bob still had his old LS1 maf in the trashcan back at his shop in Kinston. We put it in the car after it had been covered in oil dry for a week and she ran fine on the way home. I never retarded my timing but I did run some TR7 plugs.
As you can see, she did not have that LSWON top end but she'd get it done in the 1/8th.
P.S. 1.56 60fts will catch you off guard if you ain't used to them.
http://www.streetfire.net/video/1996...-wet_16053.htm
http://www.streetfire.net/video/1996...ds-n_34968.htm
I see wat u did
cptbimes is offline   Reply With Quote
Old 06-08-2010, 05:12 PM   #19
LS1Bob
LS1Bob's Avatar
LS1Bob is actually making some sense.LS1Bob is actually making some sense.LS1Bob is actually making some sense.
Send a message via AIM to LS1Bob
Good Ol' SS 540. Was there daylight under the left front tire in the first video?
'95 Mustang GT
'00 Formula
'11 GMC 2500 HD Duramax
'11 Jeep GC Overland 5.7
'13 Polaris RZR XP 900 LE
'13 Jeep JK Unlimited Rubicon
LS1Bob is offline   Reply With Quote
Old 06-08-2010, 05:40 PM   #20
98ls1transam
98ls1transam's Avatar
98ls1transam might have posted something useful at one time
98ls1transam is offline   Reply With Quote
Old 06-10-2010, 06:24 PM   #21
steve28529
steve28529's Avatar
Thanks for the info guys, picking up a compucar dry kit tomorrow. if you can think of anything else just let me know.
Old 06-10-2010, 07:19 PM   #22
Nooge
lsx>*
Nooge's Avatar
Nooge best poster evAr!!!!!!111Nooge best poster evAr!!!!!!111Nooge best poster evAr!!!!!!111
you'll be just fine with a 75-90 dry shot, like said just make sure you got plenty of fuel, wouldn't hurt to throw a 255 pump in the tank.. I've had maybe 15 bottles through my stock 4.6 with the compucar bottle in a bag dry 90 shot untuned and its still runnin just fine, went from 234 rwhp to 338rwhp off a 90 pill and ran consistent 7.61's @ 95 with a slipping clutch, 1.8 60 ft's FTL.
Mayhem Motorsports
-5.3l LSx 76mm 275 radials
Nooge is offline   Reply With Quote
Old 06-14-2010, 06:37 PM   #23
steve28529
steve28529's Avatar
Got the kit, just have to hook it up. I do have one question. It's a dry kit that goes before the maf, and I know you have to insert the nozzle tube about 6" ahead of it but. The little metal tube is about 4 inches long. Do I get the end of that metal tube 6" from the maf, or just the hole for the metal tube? in other words if I drill a hole in my intake tube 6" from the maf and insert the nozzle, the opening in the nozzle will only be about 2" from the maf.
Old 06-16-2010, 05:15 PM   #24
glasscrew
glasscrew's Avatar
glasscrew has disabled reputation
Darn I am always late on threads
glasscrew is offline   Reply With Quote
Old 06-16-2010, 05:18 PM   #25
glasscrew
glasscrew's Avatar
Here is my experience and my thoughts. I went from 125 to 200shot on a built 383. ran many passes with nos made 4 passess in one day with 200 shot. Like some of these guys say. It is okay as long as everything is done right and tuned right and the timing is retarded and you have a window switch.
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Rate This Thread:
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
