Old 04-03-2016, 06:52 PM   #76
bssmith1220
bssmith1220's Avatar
bssmith1220 is actually making some sense.bssmith1220 is actually making some sense.
I just got the same stuff from the UPS man via Fastlane....McLeod Rst, flywheel, and 26 spline input. I didn't consider the head cooling mod while the trans is out, maybe I should do that also!
2011 GMC Sierra Denali
bssmith1220 is offline   Reply With Quote
Old 04-03-2016, 06:57 PM   #77
LOL! Yes I saw your ticket in our system on Saturday! I would definitely do the head-cooling mod while the transmission is out. Simple to get to at that point and cheap insurance to prevent the head-tick common with worn valve guides.
Old 04-03-2016, 06:58 PM   #78
Originally Posted by 88MMRocket View Post
Looks good Ryan. Now only if it was as fast as your wife's red car
Sheez you know that is UM-Possiblez.
Nothing can beat the mighty LSX........
But I do have something on order that should be here in about a week........
Old 04-03-2016, 09:26 PM   #79
Ras
Resident Viking
Ras's Avatar
Ras is without a doubt too mature for this placeRas is without a doubt too mature for this placeRas is without a doubt too mature for this placeRas is without a doubt too mature for this placeRas is without a doubt too mature for this placeRas is without a doubt too mature for this placeRas is without a doubt too mature for this placeRas is without a doubt too mature for this placeRas is without a doubt too mature for this placeRas is without a doubt too mature for this placeRas is without a doubt too mature for this place
Looking good!
Also good choice on the clutch. I love the RST I put in the Mustang. Going from an Exedy Mach 600 and aluminum flywheel to the RST with a McLeod lightened steel flywheel made a world of difference.
Turning money into memories
Ras is offline   Reply With Quote
Old 04-10-2016, 08:58 PM   #80
Got my T56 back from Brinkley this week (thanks Lunchbox!).
Had to freshen it up with the 26 spline input shaft, billet bearing shaft, 2nd gear replacement, shift fork pads, and new synchros.
Ran into a problem getting the trans back into the car.
I used the plastic alignment tool and it slid in fine.
However the trans would only go about 1/4" and then stop.
I ended up having to get a 26 spline input shaft, stick it in the clutch disks, and then loosen/retighten the pressure plate to get the alignment perfect.
After that, the trans popped right into place.
Other than costing me some time today, it worked out ok.
I then installed my MGW shifter and Cobrabob's gasket set.
Next I moved under the hood to remove the supercharger and start removal of the valve covers.
Old 04-11-2016, 07:57 PM   #81
Took a few things to the powder coater today.
Old 04-12-2016, 09:02 AM   #82
cptbimes
They call me the mastadon
cptbimes's Avatar
cptbimes is without a doubt too mature for this placecptbimes is without a doubt too mature for this placecptbimes is without a doubt too mature for this placecptbimes is without a doubt too mature for this placecptbimes is without a doubt too mature for this placecptbimes is without a doubt too mature for this place
We used to hookup the clutch and disengage it via pedal all the time when swapping T56 in Fbody cars. It works like a charm every time for that last 1/2"
I see wat u did
cptbimes is offline   Reply With Quote
Old 04-17-2016, 09:03 AM   #83
LightSpeed
700hp FTL
LightSpeed's Avatar
LightSpeed is without a doubt too mature for this placeLightSpeed is without a doubt too mature for this placeLightSpeed is without a doubt too mature for this placeLightSpeed is without a doubt too mature for this placeLightSpeed is without a doubt too mature for this placeLightSpeed is without a doubt too mature for this place
Going tvs?
03 Cobra 3.4 whipple on e85
10 F150 Lariet
www.trudynosports.com
LightSpeed is offline   Reply With Quote
Old 04-17-2016, 04:34 PM   #84
Originally Posted by LightSpeed View Post
Going tvs?
You got it.
For my 99% street driven car, it should to be exactly what I need.
Old 04-19-2016, 06:54 PM   #85
LightSpeed
700hp FTL
LightSpeed's Avatar
Nice should make good power. I agree, its the best blower for a street car!
10 F150 Lariet
Old 04-19-2016, 10:03 PM   #86
Did you ever your run TVS on the cobra before switching to the whipple?
Curious if you did and what times you were able to get out of it.
Old 04-24-2016, 06:48 PM   #87
Awwwwwwww suki-suki........
Old 04-27-2016, 10:58 AM   #88
UPS Man made my day today!
Thanks to VMP!! HAHA!
Old 04-27-2016, 12:09 PM   #89
88MMRocket
88MMRocket's Avatar
88MMRocket is without a doubt too mature for this place88MMRocket is without a doubt too mature for this place88MMRocket is without a doubt too mature for this place88MMRocket is without a doubt too mature for this place88MMRocket is without a doubt too mature for this place
Nice!
88MMRocket is offline   Reply With Quote
Old 04-27-2016, 02:31 PM   #90
What size pulley? Keeping the lower stock?
Old 04-27-2016, 03:21 PM   #91
SlowGT2003
getting closer
SlowGT2003's Avatar
SlowGT2003 might have posted something useful at one timeSlowGT2003 might have posted something useful at one time
Have you got your race car back together yet?
2003 GT in pieces
2008 F350 exhaust and tuner only
2002 Civic 4 door (DD)
SlowGT2003 is offline   Reply With Quote
Old 04-27-2016, 06:02 PM   #92
No I was unemployed for 4 months so I'm just now starting to get started again.
Old 04-27-2016, 07:15 PM   #93
Made a little progress tonight. Installed S-block, intercooler, and mounted supercharger back to the engine.
The VMP instructions along with parts kits are very thorough and impressive. Great job VMP!
Old 04-27-2016, 08:06 PM   #94
LightSpeed
700hp FTL
LightSpeed's Avatar
No I sold it before I ever ran it. I did go 10.43 @ 134 with the 2.2 kb which is a turd compared to the tvs.
10 F150 Lariet
Old 04-27-2016, 10:21 PM   #95
SlowGT2003
getting closer
SlowGT2003's Avatar
I heard that. I unloaded the heads into my shop the day I got them from you and they've yet to make it to the machine shop. Ryan has completed 3 projects while I've barely scratched the surface on one. Car looks good man sorry to muck up your thread.
2003 GT in pieces
Old 04-27-2016, 11:12 PM   #96
zblackz28
LS FTW
zblackz28's Avatar
zblackz28 is without a doubt too mature for this placezblackz28 is without a doubt too mature for this placezblackz28 is without a doubt too mature for this placezblackz28 is without a doubt too mature for this placezblackz28 is without a doubt too mature for this placezblackz28 is without a doubt too mature for this placezblackz28 is without a doubt too mature for this placezblackz28 is without a doubt too mature for this place
Nice job as usual Ryan!
zblackz28 is offline   Reply With Quote
Old 04-28-2016, 05:59 AM   #97
OK thanks for that info. Man your car was flying with the Kennebell on it! I am not sure what mine will run on stock suspension and lowering springs, but if it goes low 11's on the R888's I'll be stoked.
Haha. That was funny. Good luck on your project too! I still enjoy the builds almost more than the finished product. It's the little details that I sweat on every project that seems to slow me down. LOL.
I appreciate that!
Here's a few more with that huge GT500 throttle body mocked up! Man this thing is Beau-Ti-Ful!!!!
Old 04-28-2016, 06:20 AM   #98
That's going to be a fun Cobra
Old 04-28-2016, 08:06 PM   #99
Little more progress tonight.
Got the front of engine dressed, pulley bridge installed, new TPS and new water temp sensors, etc.
Old 05-01-2016, 11:46 AM   #100
All buttoned up under hood.
Just need an updated tune file from Caleb @ Fastlane to crank it, then put 500 miles on this new McLeod clutch............
cobra, Fastlane, terminator, ttsaleen
