Old 03-27-2014, 07:04 AM   #1
Insane Perfmnse
Insane Perfmnse is a good little Junkie
what's the rules for the 28" nitrous class
Trying to figure out what to run at civil wars
Thanks
Insane Perfmnse is offline   Reply With Quote
Old 04-02-2014, 07:07 PM   #2
Race Craft Presents Ssca Outlaw Pure Street Nitrous Shootout Holcomb Motorsports Civil Wars-HDRS May 2-4th Rockingham Dragway
2000.00 to win
Rules listed below
SSCA Outlaw Pure Street Rules 2013-2014
1. 28x10.5 Slick no W's or 275-60 drag radial
2. Any rear suspension no full tube chassis. No wheelie bars.
3. Cars and trucks must keep a factory a appearance.
4. Nitrous only no turbos or supercharge combinations. No fuel injection
allowed.
5. Single stage nitrous system only. All other nitrous systems must be removed with exception fogger nozzles may be left in the intake but must be capped at the jet a plate system may be left under the carb but must be capped at the jet if not used all other hardware which includes lines, solenoids, and wiring must be removed from the unused other systems no exception. Fogger systems allowed maximum 2 nitrous solenoids an 2 fuel solenoids , plate systems allowed 2 nitrous and 2 fuel solenoids. One nitrous bottle only no pusher systems allowed. Entries may have a purge solenoid but solenoid and lines must be easily traceable.
6. A single true 4AN steel braided nitrous supply line with a max outside diameter of .310" and fitting maximum inside orfice diameter of .165" must be used. This true 4AN line must be installed in engine bay between your existing nitrous feed line and the nitrous solenoid or Yfeed to your 2 nitrous solenoids of a plate system or the Yfeed to your 2 nitrous fogger solenoids a minimum length of 4 feet on small block entries and a minimum length of 8 feet must be used on big block entries. No other lines or expansion canister allowed to feed nitrous to solenoids after this true 4AN. Lines after 4ANconnection to Y feed going to nitrous solenoids must not be of excessive length just enough to make connection from Y feed to solenoids.
7. Single carburetor on a single cast intake for all big block entries and nitrous small block entries (no cast tunnel rams with a single carburetor adapter allowed) . Natural aspirated smally block entries may use any carburated induction (tunnel ram with two carbs ok).
8. Big block 3250 LBS Small block 2850 LBS Natural aspirated entries deduct 300 LBS
RULES SUBJECT TO CHANGE TO KEEP PARITY AMONG ENGINE COMBINATIONS
All participants must comply to SSCA & Hosting track rules and safety regulations
SSCA AND TRACK RULINGS ARE FINAL FAILURE TO COMPLY ARE SUBJECT TO DISQUALIFICATION, LOSS OF ENTRY MONEY, SUSPENSION FROM SSCA, AND
SUSPENSION FROM HOSTING TRACK
Old 04-07-2014, 03:24 PM   #3
LuckyDuck
LuckyDuck is actually making some sense.LuckyDuck is actually making some sense.
What's the entry fee for this race?
I am new to the area and I think my car fits this class perfectly
LuckyDuck is offline   Reply With Quote
Old 04-07-2014, 04:19 PM   #4
LuckyDuck
Also can your run the 275 pro drag radial?
Old 04-07-2014, 04:30 PM   #5
HotSoup
HotSoup's Avatar
HotSoup has disabled reputation
I dont think you are going to draw too big of a crowd with a 4an supply line....thats what I have on my Supra...LoL.
HotSoup is offline   Reply With Quote
Old 04-07-2014, 07:11 PM   #6
SLOW88LX
still slow!
SLOW88LX's Avatar
SLOW88LX is a good little Junkie
a -4 supply line will flow more than you think
SLOW88LX is offline   Reply With Quote
Old 04-07-2014, 07:14 PM   #7
HotSoup
HotSoup's Avatar
I realize that, BUT most guys out there are NOT running a 4an line....so that puts alot of cars out automatically.
Old 04-08-2014, 01:40 AM   #8
88MMRocket
88MMRocket's Avatar
88MMRocket is without a doubt too mature for this place88MMRocket is without a doubt too mature for this place88MMRocket is without a doubt too mature for this place88MMRocket is without a doubt too mature for this place88MMRocket is without a doubt too mature for this place
X275 ran -4 lines on big blocks last year and they went 4.5xs. I'm sure if the purse is enough they will switch lines for the money.
88MMRocket is offline   Reply With Quote
Old 04-08-2014, 06:20 AM   #9
Insane Perfmnse
For my own knowledge? How much nitrous can be put through a -4 line
Old 04-08-2014, 08:24 AM   #10
Mike Fulbright told me he has about 12-15 cars committed to run his class
Old 04-08-2014, 08:25 AM   #11
It's a slick tire class but I'll ask mike about the radial
Old 04-08-2014, 08:31 AM   #12
LuckyDuck
Cool let me know it's says 28by 10.5 slick or 275/60 drag radial
But they have a 275 Pro in that size too
Thanks
Old 04-08-2014, 09:22 AM   #13
mr mopar
mr mopar's Avatar
mr mopar is a good little Junkie
They are just required a 4an from a wye under the hood to the noids in x275. These rules are 4an from bottle foward from what I read.
mr mopar is offline   Reply With Quote
Old 04-11-2014, 11:33 AM   #14
LuckyDuck
Dang seems like a small block class choking the big blocks out with weight and 4 more feet of line! LOL
Did they make a call on 275 pro or not from this class?
Thanks getting closer want to be ready
the Duck
Old 04-14-2014, 12:10 PM   #15
28's only in this class
Old 04-15-2014, 10:24 AM   #16
JBBBSTANG
JBBBSTANG is a good little Junkie
tire
your wrong blake.... it's 28x10.5 ..no W or 275 radial any brand !!! great class to run guys !!!
JBBBSTANG is offline   Reply With Quote
Old 04-15-2014, 03:14 PM   #17
LuckyDuck
So we can run the 275 pro? Just want to clarify so I can come on the right tire
Old 04-21-2014, 09:13 AM   #18
JBBBSTANG
ire
Originally Posted by luckyduck View Post
so we can run the 275 pro? Just want to clarify so i can come on the right tire
yes:d
Old 04-21-2014, 09:41 AM   #19
mr mopar
mr mopar's Avatar
The rules on the top of the page say you can.
Old 04-21-2014, 10:09 AM   #20
JBBBSTANG
tire
Mike Fulbright says you can !!!
Old 04-21-2014, 07:30 PM   #21
LuckyDuck
Awesome thanks for your help
Old 04-21-2014, 07:57 PM   #22
mustang28027
Mustang Rider
mustang28027's Avatar
mustang28027 is a good little Junkie
they will be running 4.90s to 5.0s in this class
mustang28027 is offline   Reply With Quote
Old 04-23-2014, 11:20 AM   #23
JBBBSTANG
4.90's
I don't think this will be a 4.90's class!!
Old 04-23-2014, 02:59 PM   #24
BIGBLOCKMAFIA
BIGBLOCKMAFIA's Avatar
BIGBLOCKMAFIA is without a doubt too mature for this placeBIGBLOCKMAFIA is without a doubt too mature for this placeBIGBLOCKMAFIA is without a doubt too mature for this placeBIGBLOCKMAFIA is without a doubt too mature for this placeBIGBLOCKMAFIA is without a doubt too mature for this place
.60-.70 ?
GET DEEZ BALLZ ...............
BIGBLOCKMAFIA is offline   Reply With Quote
Old 04-27-2014, 08:07 PM   #25
they will not go .60's-.70's in this class. this is going to be a great class guys
