Old 10-07-2013, 09:37 AM   #1
Ultimate Converter Concepts Street Race NOW 3500.00 to win and bonus(Ultra Street)
Ultimate Converter Concepts Concepts Street Race (Ultra Street)
www.ultimateconverter.com
October 25-27th Rockingham Dragway
NOW 3500 to win
750.00 Runner
150.00 Semi's
75.00 1/4's
75.00 Car Entry
Please support Ultimate Converter Concepts. Lenny does a lot for the Ultra Street Class so if you guys need top notch Converters please give him a call.
Rules
Here are the rules
Street Race / SR275
1/8th mile eliminator based on John Sears' Ultra Street rules. Rules are subject to change if John's rules change.
BODY:
* Must have working headlights, tail lights, stock appearing interior, carpet, door panels, factory style dash, stock floor pans and stock firewall. Firewall may be notched or smoothed as long as it remains intact and in the stock location.
* Fiberglass/Carbon body panels are limited to hood, rear deck lid, fenders, doors, and bumpers. Must be neat in appearance and not change the basic vehicle dimensions.
* Lexan windows permitted. Must be neat in appearance.
* Hood height limited to maximum 8" tall measured from the tallest part of the hood to base of the windshield (measured with a level sitting on the tallest part of the hood).
* Forward facing air inlet feeding induction on any combo add 50lbs.
* Must measure within 1" of factory wheelbase, body may not be moved from stock location
* All vehicles must maintain a minimum ride height of at least 2.5" while at rest and at race weight. No part my hang down lower that 2.5" off the ground including exhaust.
* No part of the car may protrude more than 45" forward of the front spindle centerline.
INTERIOR:
* Aftermarket steering columns are allowed.
* Must have carpet and factory type dash
ELECTRONICS:
* Optical devices are prohibited.
* Any ignition or EFI permitted.
* Progressive nitrous controllers & programmable boost controllers allowed.
ENGINE:
* Aftermarket blocks and cylinder heads are allowed.
* All entries must utilize a single carburetor cast intake manifold.
* Motor plates and solid mounts are allowed. Engine must be in stock location and not touching the stock location firewall.
* Mufflers are required on all vehicles except turbocharged combos.
* All SB power adder engines are limited to 440 cubic inches.
* BOP nitrous engines limited to 470ci
* SB N/A up to 480 cubic inch permitted with added 7 lbs. per cubic inch over 470.
* BB N/A limited to 640.
* Any engine in question will be measured with a P&G gauge. A correction factor of 1.5% will be used on P&G measurements. Competitors may be required to remove a cylinder head for bore and stroke measurements should any discrepancies arise.
INDUCTION:
* Power adder small blocks and N/A BB combinations may use a single cast intake manifold with single carb or EFI.
* Small Block N/A may use cast tunnel ram/sheetmetal/dual carbs w/weight penalty (See*below)
POWER ADDERS:
* Power adders limited to SB and BOP entries.
* Progressive nitrous controllers are allowed.
* Nitrous entries must utilize a single stage nitrous plate with all nitrous lines feeding the plate originating from the same solenoid or distribution fitting.
* Foggers must be disconnected and all solenoids must be capped off.
* Nitrous plates using fogger nozzles or multiple adjustable internal nitrous spray outlets are not allowed.
* Turbocharged (mid frame turbo only) and supercharged entries are limited to stock valve angle SB combos only. (SB CHEVY 23 DEGREE - SB FORD 20 DEGREE - 18 DEGREE MOPAR - FACTORY HEADED SMALL BLOCK FORD MOD MOTOR - LS CHEVY 15 DEGREE)
** NOTE: No raised runner heads permitted forced induction. SB Chevy 23 degree Raised Runner, SB Ford 20 degree (SR20, FT1 or T1RI or equivalent) not permitted with boosted combo
TRANSMISSION:
* Any OEM style automatic or manual transmission is allowed.
* Manual transmissions must utilize SFI approved bell housing.
REAR SUSPENSION:
* Stock type rear suspension or ladder bar only.
* Coil over shocks, anti-roll bars and aftermarket replacement control arms are allowed.
* Stock frame rails must be in factory location, notching permitted.
* Corvette permitted any type of transverse leaf spring rear suspension.
* Wheelie bars are prohibited on all cars.
FRONT SUSPENSION:
* Factory type front suspension only. Coil over shocks, aftermarket replacement control arms and aftermarket K-Members/Sub-Frames allowed.
WHEELS/TIRES:
* N/A entries allowed a 28 x 10.5 non W slick (N/A small block only), 28 x 12.50 ET Street or any 275 radial may be used.
* Power adder combos limited to a P275/60-15 DOT drag radial tire.
* Wheel width is limited to 12"
NITROUS WEIGHTS:
* All 15 degrees and above SB and BOP combos - 3200
* GM LS 15 degree & Ford TFS-R or TFS-TW with stock intake port location and height - 3100
* GM LS 15 degree & Ford TFS-R or TFS-TW with raised intake port location - 3200
* All heads 14.9 and under - 3250
* Any canted valve head - 3250
* Any non-raised intake runner 23 degree combo - 3000
* Any raised intake runner 23 degree combo - 3150
* Any non-raised intake runner 20 degree ford - 3000
* Any 20 degree raised intake runner SR20, FT1, T1RI or equivalent - 3150
* Blue Thunder, Edelbrock SC1, SBX and equivalent cylinder heads - 3300
* C3/C302B/C302/Yates style - 3150
SUPERCHARGER WEIGHTS:
* D1, V-7 JT Trim, NOVI 2000, Kenny Bell 3.6 - 3100
* F1A & V-4 J Trim -3150
* F1C & YSI - 3200
TURBO WEIGHTS:
* T-76 - 3050
* T-80 - 3200
* GT55-80 and equivalent - 3275 (Any other equivalent turbo must have prior approval.)
N/A WEIGHTS:
* Inline head - 2600
* Non-Inline head - 2700
* Big block with standard deck height and conventional head - 2900
* Big block with tall deck height and conventional head - 2950
* Big block with standard height and big chief head - 3000
* Big block with tall deck height and big chief head - 3050, over 589 add 100lbs
GENERAL:
* No Billet cylinder heads/blocks
* No Billet wheels on 80mm turbo combo (add 50lbs for 76 w/billet wheel)
* No Reducers on turbo or supercharged combo
* Alcohol/E85 legal (meth injection legal on non-intercooled combo only)
* All turbochargers (mid frame only) and superchargers must be as manufactured from factory
* No muffler required on turbo entry, required on all other combos
* No bull horns - front exit exhaust permitted but must not effect timing equipment
* Gear driven supercharger allowed
* Belt driven supercharger deduct 50 lbs
* Boosted LS 15*, TFS-R, TFS TW add 50 lbs (not permitted raised intake runner from factory height)
* Non intercooled boosted combos deduct 100lbs (no deduct if on Alcohol for fuel)
* Non intercooled boosted combos running E85 deduct 50lbs
* Front mount air to air intercooled boosted combos deduct 50lbs (no deduct if on Alcohol for fuel)
* Model years prior to 1979 or any year true leaf sprung rear suspension deduct 50lbs
* Cast tunnel ram/sheetmetal/dual carbs on SB N/A add 50 lbs
* Single 4150 carb deduct 50lbs (N/A or NOS only). 4150 based throttle body not eligible for deduction.
* V6 entries deduct 100lb
* Forward facing air inlet feeding induction add 50lbs.
What's different between SR275 and Ultra Street?
What you may want to know if you are an Ultra Street racer coming to run in Street Race.
Ultra limits power adder combos to the Mickey Thompson 3754R radial tire.
Ultra has V6s deducting 200lbs
Ultra gives the weight break to 4150 based throttle bodies.
Ultra doesn't permit TFS-R & TFS TW to run forced induction or specify LS must run OEM intake runner location.
Ultra only give a 50lb break for non-intercooled.
Ultra does not give any weight break for E85 non intercooled.
Ultra doesn't give any break for air to air intercoolers.
* Model years prior to 1979 or any year true leaf sprung rear suspension deduct 50lbs.
Ultra gives a 100lb break for leaf sprung vehicles and no break for pre-1979 bodies.
* D1, V-7 JT Trim, NOVI 2000, Kenny Bell 3.6 – 3100
Ultra doesn't give a weight for these smaller blowers.
Ultra doesn't include the J-trim in this weight bracket.
* GT55-80 and equivalent – 3275 (Any other equivalent turbo must have prior approval.)
Ultra doesn’t list a weight for the GT55-80.
* Blue Thunder, Edelbrock SC1, SBX and equivalent cylinder heads – 3300
Ultra only lists the Blue Thunder head in this category.
* GM LS 15 degree & Ford TFS-R or TFS-TW with stock intake port location and height – 3100
Ultra doesn’t include the TFS-R and TFS-TW in this category and has standard port location 15* LS grouped in the 3200lb 15 degree and up category.
* GM LS 15 degree & Ford TFS-R or TFS-TW with raised intake port location – 3200
Ultra doesn’t include this weight group, all LS 15* engines run at 3200.
Ultra just states “nitrous plates using fogger nozzles are not allowed.”
Ultra states “entries must utilize a single stage nitrous plate with one nitrous, one fuel and one redundant purge solenoid.”
Ultra limits at 632. This allows a 632 to get a clean up if a cylinder wall is scratched.
Ultra allows a nitrous BOP to go 588ci. Ultra also permits a big block Mopar to run nitrous at 588ci. Street Race does not permit BBM to use nitrous.
Ultra has these heads at 3100 which is 50lbs less than raised runner stack valve angle combos.
Ultra states “cowl hoods may not be taller than half way point of the windshield.”
Ultra doesn't permit forced induction a forward air source and states “forward facing scoops are prohibited on power adder combos unless factory installed or less than 5 inches from flat area of hood.”
Ultra doesn't include any of the above 3 body rules.
Old 10-15-2013, 01:43 PM   #2
79pacecarmod
DAMN YANKEES RACING
79pacecarmod's Avatar
79pacecarmod is without a doubt too mature for this place79pacecarmod is without a doubt too mature for this place79pacecarmod is without a doubt too mature for this place79pacecarmod is without a doubt too mature for this place79pacecarmod is without a doubt too mature for this place
Blake is there a minimum car count on this?
1979 INDY PACECAR
JUNE 2009 MODIFIED MUSTANG FEATURE CAR
www.damnyankeesracing.webs.com
79pacecarmod is offline   Reply With Quote
Old 10-15-2013, 04:14 PM   #3
dentfix
dentfix's Avatar
dentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this place
Is the 100lbs still coming off the 76?
5.16@138mph Backyard turbo mafia
dentfix is offline   Reply With Quote
Old 10-15-2013, 06:05 PM   #4
67turbogt
67turbogt's Avatar
67turbogt is actually making some sense.67turbogt is actually making some sense.
guess not, prepare to get drug!!lol
67turbogt is offline   Reply With Quote
Old 10-15-2013, 06:33 PM   #5
79pacecarmod
DAMN YANKEES RACING
You bringing camo beast out?
1979 INDY PACECAR
Old 10-15-2013, 07:42 PM   #6
67turbogt
67turbogt's Avatar
if the turbo gets back in time, i will run street race with it.
Old 10-15-2013, 07:52 PM   #7
No min car count. 100 lbs off the 76. I will decide on the 50lbs on ff turbo tomorrow. I just need to do some more research
Old 10-15-2013, 08:25 PM   #8
dentfix
dentfix's Avatar
Don't make me buy an 80 old man! If blake doesn't penalize the 76 forward facing I think it can definately be competitive.
Old 10-15-2013, 09:08 PM   #9
67turbogt
67turbogt's Avatar
guess mine will weigh 3100 then
Old 10-16-2013, 06:44 AM   #10
88MMRocket
88MMRocket's Avatar
88MMRocket is without a doubt too mature for this place88MMRocket is without a doubt too mature for this place88MMRocket is without a doubt too mature for this place88MMRocket is without a doubt too mature for this place88MMRocket is without a doubt too mature for this place
How? My Asian math must not be working right now. Call me later
88MMRocket is offline   Reply With Quote
Old 10-16-2013, 01:44 PM   #11
Bonus Money For Street Race
1000.00 Extra to win if running PCM Decals and a 500.00 Bonus if your car was tuned by PCM (or make an appointment before Civil Wars). Also, if you have bought or purchase parts from PCM up to the day of the race you will qualify for the extra 500.00 bonus. (Parts must be purchased between Oct 1st-Oct.25.
Old 10-16-2013, 02:00 PM   #12
turbotbirds
turbotbirds's Avatar
turbotbirds might have posted something useful at one time
Thanks guys! Make sure ya'll bring some stickers!
SBC S476 275DR E85 Blowthru
LJMS
Forced Inductions
FEAR THE EAR
turbotbirds is offline   Reply With Quote
Old 10-16-2013, 02:08 PM   #13
79pacecarmod
DAMN YANKEES RACING
Ok who has a set of inline heads I can use.
1979 INDY PACECAR
Old 10-16-2013, 02:11 PM   #14
dentfix
dentfix's Avatar
I'm heading over after work. Thanks blake and the rest of the pcm gang!
Old 10-16-2013, 02:42 PM   #15
What do you guys think about letting your true street bretheren with the foggers come play. It would be limited to a single nitrous solenoid with a 50 lb weight penalty with the foggers It doesn't matter to me I have just had some of the true street guys ask.
Old 10-16-2013, 03:12 PM   #16
dentfix
dentfix's Avatar
I wouldn't care as long as its limited to true street stock valve angle non rr head. Dont want nobody with gangster sb sneaking in with a fogger
Old 10-16-2013, 03:13 PM   #17
dentfix
dentfix's Avatar
Its tomorrow
Old 10-16-2013, 03:40 PM   #18
That's what I was thinking about limiting it to stock valve angle non raised runner cylinder heads. On the 50lb off. I am not going to take the 50 off because I penalize the nitrous cars for the forward facing scoop as well. So what would be good for one would be good for another right? I want you guys and everyone else to have a fighting chance at this deal. I just don't want to give to much to fast and regret it.
Old 10-16-2013, 03:46 PM   #19
dentfix
dentfix's Avatar
Fair enough
Old 10-16-2013, 05:55 PM   #20
67turbogt
67turbogt's Avatar
ok with me
Old 10-16-2013, 06:32 PM   #21
Fox Rodder
built not bought
Fox Rodder's Avatar
Fox Rodder is without a doubt too mature for this placeFox Rodder is without a doubt too mature for this placeFox Rodder is without a doubt too mature for this placeFox Rodder is without a doubt too mature for this placeFox Rodder is without a doubt too mature for this placeFox Rodder is without a doubt too mature for this placeFox Rodder is without a doubt too mature for this placeFox Rodder is without a doubt too mature for this placeFox Rodder is without a doubt too mature for this place
How much more power does a fogger make on unlimited jet over a plate? I got a big shot plate I can bring If they need it
5.16 @ 134.8 1.17 60ft
PTRA TS275 ET record
A2W & MO BOOST
coming sooner maybe later
Fox Rodder is offline   Reply With Quote
Old 10-17-2013, 12:31 AM   #22
Scrotalimpact
Scrotalimpact's Avatar
Scrotalimpact has no rep around here.
I'll be there watching, really hoping this class stays around since I may be able to compete next year with these changes I'm making.
Scrotalimpact is offline   Reply With Quote
Old 10-17-2013, 05:57 AM   #23
With a Single solenoid it won't flow anymore than a plate really. Distribution is better but the solenoid orifice is what determines how much nitrous a system can flow
Old 10-17-2013, 06:31 AM   #24
79pacecarmod
DAMN YANKEES RACING
Are you going to limit the size of it?
I have got .053 running off one pineapple on the camaro.
1979 INDY PACECAR
Old 10-17-2013, 06:37 AM   #25
dentfix
dentfix's Avatar
What size orifice would you think kevin. I was thinking a single trash can will definitely flow more than anyone is spraying on a plate wouldn't it? I know a crossbar plate will fow a ton but most can't shoot that much due to distribution.
