Old 10-07-2013, 07:39 AM   #1
How many will run T/S if I add it.
Please post here if you are definitely in . Not I might be there or if I get my junk finished in time
Old 10-07-2013, 08:58 AM   #2
79pacecarmod
DAMN YANKEES RACING
79pacecarmod's Avatar
79pacecarmod is without a doubt too mature for this place79pacecarmod is without a doubt too mature for this place79pacecarmod is without a doubt too mature for this place79pacecarmod is without a doubt too mature for this place79pacecarmod is without a doubt too mature for this place
If it can be ran on Sat so I can not mess up SR I will put the mustang and the Blazer in both classes.
I can't switch between rounds to much to change. Bad enough ill have to run the tight convertor in TS.
1979 INDY PACECAR
JUNE 2009 MODIFIED MUSTANG FEATURE CAR
www.damnyankeesracing.webs.com
79pacecarmod is offline   Reply With Quote
Old 10-07-2013, 09:01 AM   #3
turbotbirds
turbotbirds's Avatar
turbotbirds might have posted something useful at one time
I will do TS and SR as long as they are spread apart enough for me to swap turbos and carb jets! But would be better like Kevin said!
SBC S476 275DR E85 Blowthru
LJMS
Forced Inductions
FEAR THE EAR
turbotbirds is offline   Reply With Quote
Old 10-07-2013, 09:33 AM   #4
jmo363
jmo363's Avatar
jmo363 is actually making some sense.jmo363 is actually making some sense.
Ill be in for sure!!
_________________________________
TRUE STREET/REAL STREET 275
Morgan's Performance Parts
PAR Racing
Bowers Used parts
5.26 @ 133mph
jmo363 is offline   Reply With Quote
Old 10-07-2013, 09:35 AM   #5
67turbogt
67turbogt's Avatar
67turbogt is actually making some sense.67turbogt is actually making some sense.
in
67turbogt is offline   Reply With Quote
Old 10-07-2013, 11:49 AM   #6
SETOMPK
Sore Loser!!!
SETOMPK's Avatar
SETOMPK is a good little Junkie
I'm in 100%
Fuckin me? Now I'm Fuckin you LIL HO!!!
SETOMPK is offline   Reply With Quote
Old 10-08-2013, 06:44 AM   #7
79pacecarmod
DAMN YANKEES RACING
Better take me off the list may not have a engine for yellow. Blazer may still run.
1979 INDY PACECAR
Old 10-08-2013, 08:02 AM   #8
I can't run a race with 4-5 cars. I would need at least 8-16 cars to make it a race without a sponsor.
Old 10-08-2013, 09:20 AM   #9
LS1EXCITEMENT
RAM AIR 6
LS1EXCITEMENT's Avatar
LS1EXCITEMENT is without a doubt too mature for this placeLS1EXCITEMENT is without a doubt too mature for this placeLS1EXCITEMENT is without a doubt too mature for this placeLS1EXCITEMENT is without a doubt too mature for this placeLS1EXCITEMENT is without a doubt too mature for this placeLS1EXCITEMENT is without a doubt too mature for this placeLS1EXCITEMENT is without a doubt too mature for this placeLS1EXCITEMENT is without a doubt too mature for this place
Won't be able to make this one, but Ted will be there with big bird!
LS1EXCITEMENT is offline   Reply With Quote
Old 10-08-2013, 10:16 AM   #10
Fox Rodder
built not bought
Fox Rodder's Avatar
Fox Rodder is without a doubt too mature for this placeFox Rodder is without a doubt too mature for this placeFox Rodder is without a doubt too mature for this placeFox Rodder is without a doubt too mature for this placeFox Rodder is without a doubt too mature for this placeFox Rodder is without a doubt too mature for this placeFox Rodder is without a doubt too mature for this placeFox Rodder is without a doubt too mature for this placeFox Rodder is without a doubt too mature for this place
I'm out I got a cylinder that apparently has a hurt ring its 30 low.After torching heads and blowing gaskets I'm just staying out the rest of the season.
5.16 @ 134.8 1.17 60ft
PTRA TS275 ET record
A2W & MO BOOST
coming sooner maybe later
Fox Rodder is offline   Reply With Quote
Old 10-08-2013, 10:43 AM   #11
jmo363
jmo363's Avatar
Combine the class Blake If you cant get the car count up.
PAR Racing
Bowers Used parts
5.26 @ 133mph
Old 10-08-2013, 07:44 PM   #12
dentfix
dentfix's Avatar
dentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this placedentfix is without a doubt too mature for this place
I'm putting the shortblock together tonight. Might get it fired this weekend. Can't say I'll definagely be there but it looks pretty good right now. I don't care which class runs as long as the 76 is a reasonable weight. I think 150lbs off of true street weight for all combos would be fair to merge the classes. Real street record is 5.16 and ultimate has a bunch in the 5.0's with a best of 5.01 and that was all on the old mickeys. They can easily go 4.90's on the pro tire. True street cars would be lucky to go 5.09 with 150 out. Just my opinion
5.16@138mph Backyard turbo mafia
dentfix is offline   Reply With Quote
Old 10-08-2013, 07:59 PM   #13
401k
401k's Avatar
401k has no rep around here.
Possible mine maybe done
401k is offline   Reply With Quote
Old 10-08-2013, 08:52 PM   #14
BIGBLOCKMAFIA
BIGBLOCKMAFIA's Avatar
BIGBLOCKMAFIA is without a doubt too mature for this placeBIGBLOCKMAFIA is without a doubt too mature for this placeBIGBLOCKMAFIA is without a doubt too mature for this placeBIGBLOCKMAFIA is without a doubt too mature for this placeBIGBLOCKMAFIA is without a doubt too mature for this place
getting my junk together with some updates tonight.. can someone tell me where the classes and rules and dates are for this.. I am in if I fit in
GET DEEZ BALLZ ...............
BIGBLOCKMAFIA is offline   Reply With Quote
Old 10-08-2013, 09:50 PM   #15
dentfix
dentfix's Avatar
Got 7 pistons in. Found one top ring that was egg shaped lol
Ordered everything else in need to get it back together tonight.
Old 10-08-2013, 10:59 PM   #16
turbotbirds
I should be dropping mine back in tomorrow night so you can come by and pick up Bryan's "community" cherry picker back up! Hope I don't need it again until this season is over, LOL!
If there are not enough cars for True Street, I think it is a good idea to get the True Street cars in with Street Race as well. Put the 76mm at 3100 or 3050 base weight and give the big block cars a little extra jet, JMO!
LJMS
Forced Inductions
FEAR THE EAR
Old 10-09-2013, 06:36 AM   #17
79pacecarmod
DAMN YANKEES RACING
I'm definitely out sold top end of motor.
Prob just bring camaro and run outlaw275.
Can't wait for the 2014 T/S rules and my new non dirt track heads.
1979 INDY PACECAR
Old 10-09-2013, 11:56 AM   #18
BIGBLOCKMAFIA
I just found the rules and if I gotta run n/a to race in this class count me out .aint wasting time or money to carry a pea shooter up against a cannon
Old 10-09-2013, 02:01 PM   #19
I am going to drop the base weight 50 lbs for the t-76 cars. With the deductions we already give vs they give no deductions in ultra. You would be 100lbs lighter than the T-80 and 175 lbs lighter than the with no deductions. I think almost 200lbs lighter you guys should be about to compete
Old 10-09-2013, 02:59 PM   #20
Ryans_Pewter_SS
Ryans_Pewter_SS's Avatar
Ryans_Pewter_SS is actually making some sense.Ryans_Pewter_SS is actually making some sense.
where can i find the rules?
Ryans_Pewter_SS is offline   Reply With Quote
Old 10-09-2013, 03:21 PM   #21
dentfix
dentfix's Avatar
So that makes 3100 base weight? Then deduct 50 for non intercooled and add 50 for forward facing = 3100 for me ? So basically 50lbs lighter than true street against cars trapping 139-142mph
Old 10-09-2013, 03:26 PM   #22
dentfix
dentfix's Avatar
Those rules are all wrong david (bigblockmafia). Im pretty sure That's the ones that were posted all last winter and then got changed right before the first race.
Old 10-09-2013, 03:28 PM   #23
79pacecarmod
DAMN YANKEES RACING
So how many of you guys are going to the Farm this weekend to support true street?
1979 INDY PACECAR
Old 10-09-2013, 03:29 PM   #24
dentfix
dentfix's Avatar
I'm pretty sure these are the current rules
http://www.king-of-the-streets.org/S...les%202013.htm
Old 10-09-2013, 03:30 PM   #25
BIGBLOCKMAFIA
how does that not fucking surprise me..lol fixed it with the delete button ahahahhhhhhhhhhhhahahhhahahahhahahhhhhhhhhhhhhhhhh hhhhhhhhhaaaaaaaaaaaaaaaa
bbmafiabitchesmost.neverranarace
