Old 04-14-2019, 07:06 PM   #1
Cool new gauges
To go along with the carb project for the 454SS I am adding a wideband and changing the existing trans temp gauge.
The existing trans temp gauge:
The new pocket that I cut up, had to remove the back, then I fit a piece of plastic to hold the gauges
The new gauges:
I still have to do the wiring for both and install the O2 sensor in the exhaust.
Old 04-15-2019, 05:54 AM   #2
That's definitely a lot better looking!
Where'd you get the textured plastic from? That's what I've been wanting to make my gauge bezel out of.
Old 04-15-2019, 06:29 AM   #3
Looks much better!
Old 04-16-2019, 06:22 PM   #4
Cool
Thanks guys!
Hotwire, I found the plastic on eBay. The pieces I got are about 6x12" ABS, got one 1/16" thick and one 1/8" thick. I used the 1/16 for this project.
From this seller: https://www.ebay.com/sch/fplastics/m...p2047675.l2562
Old 04-16-2019, 07:50 PM   #5
looks good
Old 04-27-2019, 03:47 PM   #6
Cool
I got most of this project finished up. I redid the plastic mounting plate with the thicker material and got it to fit better. I did all the wiring and connected the lighting to the factory dash control. The old gauge was wired so the light was always on. Now the gauges illuminate with the headlight switch and also dim.
lights on:
Only thing left is drilling a hole in the exhaust somewhere and installing the O2 sensor.
Anyone have a TIG welder?
Old 05-13-2019, 11:42 AM   #7
Cool
I got this finished up today using a clamp on bung.
