Old 11-16-2012, 12:49 PM   #1
SR275/Budget Street
Here is a class that a lot of you guys might be interested. These are the preliminary rules and may change somewhat. Let me know what you think. The objective for this class is to be an actual street car class.
Budget Street
BODY & GLASS:
* Must have working headlights, tail lights, stock appearing interior, carpet, door panels, factory dash, full stock floor pans, stock firewall.
* Lexan windows prohibited.
* Hood height limited to maximum 4" tall measured from the tallest part of the hood to base of the windshield.
* Turbo and superchargers not permitted forward facing air source.
* Fiberglass body panels limited to hood only except for OEM parts.
* Must measure within 1" of factory wheelbase, body may not be moved from stock location
* All vehicles must maintain a minimum ride height of at least 2.5" while at rest and at race weight. No part my hang down lower that 2.5" off the ground including exhaust.
* All cars must maintain factory front overhang and OEM style front bumper.
* All vehicles minimum weight with driver 3200lbs.
SUSPENSION:
* No wheelie bars.
* Bolt on stock suspension only. No welded on parts allowed including anti-roll.
* Rear coil-overs not allowed.
* All vehicles must retain the full factory frame rails. Notching for rear tire clearance is permitted. Notches must be on outside portion of frame only.
TIRES
* All power adder entries must use DOT drag radial drive tires with a maximum allowed size of 275/50R15.
* Tires must maintain at least 2/32 tread depth until first round of eliminations.
POWER ADDERS
* Single type power adder only.
NITROUS
* No multiple stages permitted.
Second kit wiring and feed lines must be fully removed.
If a car is found with a second stage hooked up on the track property, the racer will be disqualified from the event with no entry refund.
* Only one 10lb nitrous bottle allowed in car at a time.
* Small block nitrous limited to a removable single spray bar nitrous plate and maximum solenoid orifice size of .098.
FORCED INDUCTION
* No billet wheels allowed
* Max turbo size 70mm measured tip to tip. (no reducers allowed to achieve this size and no clipped wheels)
* All turbos must utilize the original turbo manufacturers wheels for the turbo being used. No swapping to different manufacturers, 2nd party or custom wheels.
* You may be required at any time to remove your turbo and/or your turbo cover to be checked.
*Maximum supercharger sizes T-trim or P-1SC. Must be side slinger belt driven.
* Air to air intercooler OR water meth injection allowed not both.
* Air to water type intercooler not permitted. Any intercooler that uses water, ice, spray bars, dry ice or any other cooling medium is considered in this category.
EXHAUST
* Mufflers required on all entries.
* Exhaust must route under the car and extend to at least behind the drivers seat.
CYLINDER HEAD / ENGINE INDUCTION
* Small block, 6cyl or 4cyl only.
* OEM passenger vehicle engine blocks only.
* All cylinder heads must be non raised intake runner must maintain the automobile OEM intake manifold bolt pattern. Ford TFS TW non-R permitted.
* Maximum cylinder head intake runner volume 225cc.
* Buick, Pontiac, Oldsmobile combos permitted if 440ci or less.
* Cast single 4150 type or non converted fuel injection type manifolds only.
* All cars must have a radiator.
FUEL
* Gasoline is the only fuel permitted.
Methanol only allowed in a 50/50 mix with water on non intercooled cars only.
ELECTRONICS
* Any ignition or EFI permitted.
* Progressive nitrous controllers & programmable boost controllers allowed.
* All cars must have a working alternator in use.
WEIGHT PENALTIES AND DEDUCTIONS
* SB nitrous - 8.2 deck or modular deduct 50lbs
Old 11-16-2012, 12:55 PM   #2
HITMAN
Cause racecar
HITMAN's Avatar
HITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this placeHITMAN is without a doubt too mature for this place
I'm diggin it......
Sent from my PC36100 using Tapatalk 2
HITMAN is offline   Reply With Quote
Old 11-16-2012, 01:13 PM   #3
Remember these are preliminary. I think we could include some of the whipple, eaton, and kenne bell stuff in the supercharger rules.
Old 11-16-2012, 01:29 PM   #4
Easy now
Roll Tide
Easy now's Avatar
Easy now has no rep around here.
Now were talking!!... I like it..
Easy now is offline   Reply With Quote
Old 11-16-2012, 01:41 PM   #5
First thing I saw was no A2W. That excludes nearly all the factory supercharged stuff.
After looking at the A2W category, I'm confused.
Old 11-16-2012, 01:53 PM   #6
HITMAN
Cause racecar
HITMAN's Avatar
What is the max cubic inch?
Old 11-16-2012, 02:20 PM   #7
1SLOLT1
1SLOLT1's Avatar
1SLOLT1 has no rep around here.
Figures, we just put an anti-roll on the wife's car. Fits all the other rules though.
07 Z06 - Stock
1SLOLT1 is offline   Reply With Quote
Old 11-16-2012, 02:36 PM   #8
These are preliminary. We would want to include all the factory supercharged stuff so that shouldn't be an issue. Keep suggestions coming. We aren't perfect and we forget sometimes.
Old 11-16-2012, 02:41 PM   #9
1SLOLT1
1SLOLT1's Avatar
What about a single nitrous nozzle? See those a lot on street cars.
07 Z06 - Stock
Old 11-16-2012, 02:43 PM   #10
budget
You can still run it just unhook the anti-roll bar
Old 11-16-2012, 02:46 PM   #11
1SLOLT1
1SLOLT1's Avatar
Just to be clear its a drag/sway bar.
http://www.umiperformance.com/catalo...roducts_id=326
It bolts on to factory mounts, just recommends welding for strength.
07 Z06 - Stock
Old 11-16-2012, 02:47 PM   #12
rs
You can run that piece with the links unhooked. That is basically an anti-roll bar whether it bolts in or welds in
Old 11-16-2012, 02:50 PM   #13
1SLOLT1
1SLOLT1's Avatar
is it bolted in or welded in?
Its bolted on, they just recommend welding the body mounting bracket for extra strength.
If you look at images 11 & 12 you can see the mounting brackets I am talking about.
07 Z06 - Stock
Old 11-16-2012, 02:55 PM   #14
rs
yes that will be okay
Old 11-16-2012, 02:59 PM   #15
1SLOLT1
1SLOLT1's Avatar
I guess I don't see the difference between this and the factory sway bar other than it is a lot larger in diameter. Thanks for answering my questions though.
07 Z06 - Stock
Old 11-16-2012, 03:03 PM   #16
So stock rear sway bars are allowed but none of the aftermarket swaybars that don't mount to the stock locations?
I only ask because I have a maximum motorsports "street" swaybar.
http://www.maximummotorsports.com/st...roducts_id=550
Sounds like fun either way.
When you say gasoline I assume you mean any octane? Why not E85?
Old 11-16-2012, 03:11 PM   #17
HITMAN
Cause racecar
HITMAN's Avatar
That's just like an upgraded factory option. That should be allowed I would think
Old 11-16-2012, 03:24 PM   #18
NSTIGATR
Glide and two stages...
NSTIGATR's Avatar
NSTIGATR is without a doubt too mature for this placeNSTIGATR is without a doubt too mature for this placeNSTIGATR is without a doubt too mature for this placeNSTIGATR is without a doubt too mature for this placeNSTIGATR is without a doubt too mature for this placeNSTIGATR is without a doubt too mature for this placeNSTIGATR is without a doubt too mature for this placeNSTIGATR is without a doubt too mature for this placeNSTIGATR is without a doubt too mature for this placeNSTIGATR is without a doubt too mature for this placeNSTIGATR is without a doubt too mature for this place
Well I liked it but I'm out for the turbo size. Looks to be a fun class though.
Peace, through superior firepower.
Fear causes hesitation, and hesitation will cause your worst fears to come true. You project strength to avoid conflict.
NSTIGATR is offline   Reply With Quote
Old 11-16-2012, 03:25 PM   #19
fairmont357
fairmont357's Avatar
fairmont357 is without a doubt too mature for this placefairmont357 is without a doubt too mature for this placefairmont357 is without a doubt too mature for this placefairmont357 is without a doubt too mature for this placefairmont357 is without a doubt too mature for this placefairmont357 is without a doubt too mature for this place
Let's go!!!!! I've got 275/40 17s on it would that be legal?
82 gt t top
78 fairmont lifetime commitment
93 reef blue hatch 2.3 auto for my son
89 Saleen vert #415
fairmont357 is offline   Reply With Quote
Old 11-16-2012, 04:10 PM   #20
The reason is because that sway bar is basically an anti roll bar. I wil look at the maximum Motorsports one
Old 11-16-2012, 04:30 PM   #21
lukeduke
Boost is my antidrug
lukeduke's Avatar
lukeduke is without a doubt too mature for this placelukeduke is without a doubt too mature for this placelukeduke is without a doubt too mature for this placelukeduke is without a doubt too mature for this placelukeduke is without a doubt too mature for this placelukeduke is without a doubt too mature for this placelukeduke is without a doubt too mature for this place
What are the weights gonna be like?
1987 Cutlass Supreme Brougham: AKA "GAM GAM"
lukeduke is offline   Reply With Quote
Old 11-16-2012, 04:32 PM   #22
401k
401k's Avatar
401k has no rep around here.
A possible great class !
401k is offline   Reply With Quote
Old 11-16-2012, 04:40 PM   #23
427SN95
427SN95's Avatar
427SN95 is without a doubt too mature for this place427SN95 is without a doubt too mature for this place427SN95 is without a doubt too mature for this place427SN95 is without a doubt too mature for this place427SN95 is without a doubt too mature for this place427SN95 is without a doubt too mature for this place
4.0 whipple?
SOLD--2003 Sonic Cobra kb 2.6 solid rear TH400, hoosierdaddy tires.
Best time so far 10.28 at 135
427SN95 is offline   Reply With Quote
Old 11-16-2012, 04:45 PM   #24
SuperDan
Burnin' Rubber
SuperDan's Avatar
SuperDan is without a doubt too mature for this placeSuperDan is without a doubt too mature for this placeSuperDan is without a doubt too mature for this placeSuperDan is without a doubt too mature for this placeSuperDan is without a doubt too mature for this placeSuperDan is without a doubt too mature for this place
Yes. Yes. Fuck yes. IN! Now finish my shit so I can start a SR275 build thread!
SuperDan is offline   Reply With Quote
Old 11-16-2012, 04:46 PM   #25
SuperDan
Burnin' Rubber
SuperDan's Avatar
I'd say at least 3 speeds. NO POWERGLIDES!
*POVERTY STREET 275, 33x12.50 BFG A/T KO, 351wessorttf, AllLSguysarecheaters?, bracketracingisntracing, BudgetStreet=Daycare, DentGotSBF&TerrysNutsGotCooold, Hmmm Why Are RS275 Guys Hating So Much?, Juiced5.3 is a LIAR, makelotsatagsbutdrivecamryftl, MoreBitchesThanRealStreet, PS275, SR275JoinsTurboUnion, TalksShitButCouldntFinishQualifying
