Old 03-01-2018, 07:13 PM   #26
I like it!
manual trans will be cool and fun!
Old 03-18-2018, 02:56 PM   #27
Bought a new carb, distributor, water pump pulley, crank pulley, mini starter, fuel pump, etc.. Also needed to get something on the car to keep it from going downhill until I can get it into the garage. Quick satin job for now.
Old 03-19-2018, 06:29 AM   #28
That turned out nice
Old 03-19-2018, 07:01 AM   #29
robertmee
robertmee's Avatar
robertmee is actually making some sense.robertmee is actually making some sense.
Like the color!
robertmee is offline   Reply With Quote
Old 03-19-2018, 10:16 AM   #30
very nice
Old 03-19-2018, 08:42 PM   #31
Dang man! That's sweet!. As many projects as you have roll through your place, you're going to have to start a business before too long!
http://horsepowerjunkies.com/forums/...hlight=mock-up
Old 03-19-2018, 09:13 PM   #32
have you started your car yet "Tubbed440"
Old 05-03-2018, 06:26 PM   #33
Getting so close I can almost taste it. Got the new clutch and pressure plate, hydraulic clutch master/slave all ready to go as well..
Old 05-03-2018, 09:03 PM   #34
looking good
Old 05-03-2018, 09:18 PM   #35
What hydraulic setup did you use?
Old 05-04-2018, 04:56 AM   #36
Just stock replacement GM stuff out of the same vehicle the transmission came from.
Old 05-22-2018, 06:17 PM   #37
56 is finally on the way from the back yard to the garage for it's turn!!!
Old 05-23-2018, 10:12 AM   #38
Hell yea! Can't wait to see what you're doing with this one.
Where'd you pick the wheels up from?
Old 05-23-2018, 11:43 AM   #39
My buddy wanted new wheels for his C10, so I offered to buy these from him.
4 wheels with new tires. $700 I am happy with them.
Old 05-23-2018, 09:45 PM   #40
very nice
Old 05-24-2018, 11:19 AM   #41
Should be, they look good!
Old 05-30-2018, 02:12 PM   #42
Got home from vacation Sunday, threw engine/transmission in Monday
Old 05-30-2018, 03:37 PM   #43
nice
Old 06-04-2018, 09:18 AM   #44
Had a productive weekend.
Friday at lunch I scraped the barnacles off the dash and painted it, and installed a new brake booster, master cylinder, got it hooked up to the brake pedal.
Saturday I installed a new steering column, I lucked out and it dropped right in like it was made for it. I measured for all the linkage from the column to the power steering box and got that ordered. I pulled the front coil springs to drop the front of the car a bit, replaced the front rotors, inner & outer wheel bearings, seal, etc. Installed new shocks front and rear.
Sunday I figured out how to mount the radiator using some crap/scrap I had kicking around, not the best looking, but will work. Also cut the transmission tunnel for the shifter, modified the shifter that came with the transmission. Then installed the hydraulic clutch, tucked the clutch master in right beside the brake booster, and made a bracket off the clutch pedal arm to mount the rod to.
Moving right along, it's amazing what a difference a few weeks can make.
Old 06-05-2018, 06:23 AM   #45
Nice work man, is that a truck clutch master?
Old 06-05-2018, 09:09 AM   #46
Yes, it is a master out of a 1993 Chevy 1500
Yesterday I was able to install the driveshaft (ordered custom from a place in Winston Salem on Tuesday, showed up Monday.. Very impressed!) and installed the steering linkage from the box to the column.
Old 06-06-2018, 09:07 AM   #47
Looks good
Old 07-14-2018, 01:38 PM   #48
Finally pushed it out for some pics with the trim on.. I think the only thing that I am waiting on is the gas tank to arrive this week, then I think I can drive it!!
Old 07-14-2018, 07:17 PM   #49
I dig it!
Old 07-14-2018, 09:52 PM   #50
Bad ass man, I've got to start researching trim hardware and getting it installed too.
