Old 09-10-2018, 01:50 PM   #1
Post Proform carb parts?
Anyone have any experience with them good or bad?
I have been looking into replacement billet base plates for the 750 vacuum secondary carb on the wife's truck.The Proform units look pretty nice, the price is good and I can get it from Advance Auto with some nice online discount codes. I have also been looking at the main body replacement. This would eliminate the choke and be like a Holley HP style.
I have read where Quick Fuel uses the same parts just in different colors... Not sure if this is still true but the parts look identical in most of the pictures I have seen.
Most of what I have read has been decent. The biggest negative so far for me is the purple color of the base plate. Sliver, red or black would be better for the overall color scheme under the hood but if it works I'll deal with the purple...
Old 09-10-2018, 03:43 PM   #2
Cool
This is the main body I'm looking at
https://www.summitracing.com/parts/p...c/applications
this is the throttle plate
https://www.summitracing.com/parts/pro-67148/overview/
Old 09-10-2018, 05:03 PM   #3
ive used them they worked great, look at QFT as well for different colors
Old 09-10-2018, 06:36 PM   #4
Cool
Cool thanks
The QFT ones are quite a bit more money for what looks to be the same thing...
Old 09-11-2018, 05:25 AM   #5
lol they are the same, I bought a "ProForm" Annular 750 new last year and when I took the bowls off to change jest the main body was embossed with "QFT" behind the metering block
Old 09-11-2018, 01:44 PM   #6
LOL
I think I'm just gonna buy the stuff and see how it goes!
Old 10-02-2018, 02:00 PM   #7
I bought the main body and base plate, no idea when I will get to swapping it all out... I'm now also looking to see if I can make this a 4 corner idle setup without too much extra work.
Old 02-13-2019, 06:08 PM   #8
I ended up getting a set of Quick Fuel metering blocks as well.
Today I started modifying them! I moved the IFR to the lower position and plugged the lower emulsion bleed.
It's loads of fun drilling the tiny set screws too...
Old 02-13-2019, 06:16 PM   #9
These are the blocks I got
https://www.jegs.com/i/Quick-Fuel/79...05QFT/10002/-1
Old 02-26-2019, 06:50 PM   #10
Cool
Today I added restrictions to the main body for the transfer slots. A little easier dealing with a 10-32 set screw compared to the 6-32 ones in the metering blocks!
before:
drilled to tap:
restriction in place:
10-32 set screws:
main body:
Old 02-28-2019, 02:50 PM   #11
A couple mock-up pics of the Frankencarb I'm building:
I am going to be reusing the gold fuel bowls off the existing carb on the truck and the QFT adjustable vacuum can. Hopefully most of it will be covered by the air cleaner...
Old 03-01-2019, 01:25 PM   #12
Snowman
Snowman's Avatar
Snowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this placeSnowman is without a doubt too mature for this place
whats a carb? LOL
1985 Iroc
1986 Iroc
2009 G8 GT
Snowman is offline   Reply With Quote
Old 03-01-2019, 02:08 PM   #13
Talking
Originally Posted by Snowman View Post
whats a carb? LOL
the old dumb fuel mixer!
Old 05-06-2019, 05:28 PM   #14
Cool
I pulled the old carb off the truck so I could reuse some of the parts on the new setup.
I had to grind the side of the new main body a bit as well as the vacuum canister for proper fit.
And in it's place:
Old 05-07-2019, 02:03 PM   #15
Heck ya!
