Go Back   HorsepowerJunkies.com Forums > Car Related Discussion > The Garage
Old 09-10-2018, 02:50 PM   #1
Post Proform carb parts?
Anyone have any experience with them good or bad?
I have been looking into replacement billet base plates for the 750 vacuum secondary carb on the wife's truck.The Proform units look pretty nice, the price is good and I can get it from Advance Auto with some nice online discount codes. I have also been looking at the main body replacement. This would eliminate the choke and be like a Holley HP style.
I have read where Quick Fuel uses the same parts just in different colors... Not sure if this is still true but the parts look identical in most of the pictures I have seen.
Most of what I have read has been decent. The biggest negative so far for me is the purple color of the base plate. Sliver, red or black would be better for the overall color scheme under the hood but if it works I'll deal with the purple...
Old 09-10-2018, 04:43 PM   #2
Cool
This is the main body I'm looking at
https://www.summitracing.com/parts/p...c/applications
this is the throttle plate
https://www.summitracing.com/parts/pro-67148/overview/
Old 09-10-2018, 06:03 PM   #3
ive used them they worked great, look at QFT as well for different colors
1979 CAMARO 383ci, 3.42 gear 10.96 @ 122 footbraking through the mufflers
Old 09-10-2018, 07:36 PM   #4
Cool
Cool thanks
The QFT ones are quite a bit more money for what looks to be the same thing...
Old 09-11-2018, 06:25 AM   #5
lol they are the same, I bought a "ProForm" Annular 750 new last year and when I took the bowls off to change jest the main body was embossed with "QFT" behind the metering block
Old 09-11-2018, 02:44 PM   #6
LOL
I think I'm just gonna buy the stuff and see how it goes!
Old 10-02-2018, 03:00 PM   #7
I bought the main body and base plate, no idea when I will get to swapping it all out... I'm now also looking to see if I can make this a 4 corner idle setup without too much extra work.
Old 02-13-2019, 07:08 PM   #8
I ended up getting a set of Quick Fuel metering blocks as well.
Today I started modifying them! I moved the IFR to the lower position and plugged the lower emulsion bleed.
It's loads of fun drilling the tiny set screws too...
Old 02-13-2019, 07:16 PM   #9
These are the blocks I got
https://www.jegs.com/i/Quick-Fuel/79...05QFT/10002/-1
