Go Back   HorsepowerJunkies.com Forums > Car Related Discussion > The Garage
Old 01-08-2018, 08:32 AM   #1
-3AN thread pitch? & clutch line question
DISCLAIMER: I have never owner or touched AN fittings before.
Using a Tilton 75 series master cylinder for my clutch setup (GTO T56, stock slave). The port is -3AN.
http://tiltonracing.com/wp-content/u...Cylinder-1.pdf
The port comes out of the end of the slave. I want to have a right angle fitting at the end of the slave pointing down, instead of having a line coming straight out.
I can do a 90 degree AN fitting or banjo. I'd like to do the banjo fitting, but cannot figure out what to order? I need to go from -3AN banjo to -4AN line..
The slave cylinder adapter is -4AN. https://www.summitracing.com/parts/rus-641001
So I'll have to measure and order a -4AN line to go from clutch to slave, just need to figure out the banjo I need to order. Can anyone help?
More or less mimicing this $650 setup: http://www.chevelles.com/forums/3154229-post12.html
Old 01-08-2018, 08:39 AM   #2
HotSoup
HotSoup's Avatar
HotSoup has disabled reputation
90 3an....dont know why you feel the need for a 4an line.
HotSoup is offline   Reply With Quote
Old 01-08-2018, 08:50 AM   #3
robertmee
robertmee's Avatar
robertmee is actually making some sense.robertmee is actually making some sense.
When I was doing all my AN fittings I just called summit tech support....that or went to Ashworths speed shop and trial and error put stuff together. But summit was very helpful.
robertmee is offline   Reply With Quote
Old 01-08-2018, 09:01 AM   #4
Because the only AN adapter for the stock slave is -4AN. Both Russel and Earl's carry the same adapter, both -4AN.
Old 01-08-2018, 09:03 AM   #5
Preciate it. I've already put a call into them once. Now that I've found the AN adapter for the slave I'm better suited to talk with them.
I can't find any banjo that just bolt to the master, I might have to use the 3/16" adapter that comes w/ the slave then put a banjo on it?
Old 01-08-2018, 09:20 AM   #6
HotSoup
HotSoup's Avatar
Most are 10mm x1.0 banjo. Not sure on the tilton though, I have a tilton master, just dont have time to check it right now.
Instead of an adapter id do 3an 90 to 4an on the line.
https://www.ebay.com/itm/ALLSTAR-40-...RaLbAO&vxp=mtr
Old 01-08-2018, 09:23 AM   #7
very much appreciate the link! That's exactly what I need and it'd cut down on the connections too. Just have to measure my car to make sure the length is right.
Thank you!!
Old 01-08-2018, 11:58 AM   #8
Mr. E
Mr. E's Avatar
Mr. E best poster evAr!!!!!!111Mr. E best poster evAr!!!!!!111Mr. E best poster evAr!!!!!!111Mr. E best poster evAr!!!!!!111
Fwiw the clutch master should be a female npt port. It just has an npt to -3 an adapter.
Mr. E is offline   Reply With Quote
Old 01-08-2018, 02:18 PM   #9
I contacted Tilton for shits and giggles, response I got:
Port is AN-3. Or 3/8-24 threads
If I get time tonight I'll check to see if that's right. (or that I have the right size bolt to try it)
*EDIT* - quick google confirmed it: https://en.wikipedia.org/wiki/AN_thread
